Nextcloud version (eg, 18.0.2): Nextcloud version 16.0.5
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): nginx version: nginx/1.14.0 (Ubuntu)
PHP version (eg, 7.1):
PHP 7.2.24-0ubuntu0.18.04.7 (cli) (built: Oct 7 2020 15:24:25) ( NTS )
Copyright © 1997-2018 The PHP Group
Zend Engine v3.2.0, Copyright © 1998-2018 Zend Technologies
with Zend OPcache v7.2.24-0ubuntu0.18.04.7, Copyright © 1999-2018, by Zend Technologies
I wanted to upgrade from 16 to 20.
Reading documentation i found that you have to go every major release…16,17,18,19 and then 20.
I upgraded with the built-in tool inside nextcloud local server.
I rebooted and found: error nternal server.
I get with logs that mysql database wasnt working as expected.
So i delete the old config.php i had in order to generate a new one.
So i enter in install ( create a CAN_INSTALL file in nextcloud folder and
filling data:
Then i got this error:
Error while trying to initialise the database: An exception occurred while executing ‘SELECT version
FROM oc_migrations
WHERE app
= ? ORDER BY version
ASC’ with params [“core”]: SQLSTATE[42S02]: Base table or view not found: 1932 Table ‘nextcloud16.oc_migrations’ doesn’t exist in
","args":["AppManager"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":346,"function":"getAppManager","class":"OC\\Server","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":114,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/base.php","line":640,"function":"loadApps","class":"OC_App","type":"::","args":[["session"]]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/base.php","line":1078,"function":"init","class":"OC","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/index.php","line":40,"args":["\/usr\/share\/nginx\/nextcloud16\/lib\/base.php"],"function":"require_once"}],"File":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php","Line":90,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1932 Table 'nextcloud16.oc_appconfig' doesn't exist in engine","Code":"42S02","Trace":[{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php","line":88,"function":"query","class":"PDO","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":908,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDOConnection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[]]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":329,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":107,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":285,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":885,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/Server.php","line":504,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":161,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["MemCacheFactory"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/Server.php","line":1537,"function":"query","class":"OC\\ServerContainer","type":"->","args":["MemCacheFactory"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/Server.php","line":692,"function":"getMemCacheFactory","class":"OC\\Server","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":161,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["AppManager"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/Server.php","line":1727,"function":"query","class":"OC\\ServerContainer","type":"->","args":["AppManager"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":346,"function":"getAppManager","class":"OC\\Server","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":114,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/base.php","line":640,"function":"loadApps","class":"OC_App","type":"::","args":[["session"]]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/base.php","line":1078,"function":"init","class":"OC","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/index.php","line":40,"args":["\/usr\/share\/nginx\/nextcloud16\/lib\/base.php"],"function":"require_once"}],"File":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php","Line":88}},"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:82.0) Gecko\/20100101 Firefox\/82.0","version":"17.0.10.1"}
{"reqId":"aDV8LwVLLSCRHbxNyH5N","level":3,"time":"November 16, 2020 13:56:51","remoteAddr":"127.0.0.1","user":"--","app":"core","method":"GET","url":"\/","message":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing 'SELECT * FROM `oc_appconfig`':\n\nSQLSTATE[42S02]: Base table or view not found: 1932 Table 'nextcloud16.oc_appconfig' doesn't exist in engine","Code":0,"Trace":[{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php","line":169,"function":"convertException","class":"Doctrine\\DBAL\\Driver\\AbstractMySQLDriver","type":"->","args":["An exception occurred while executing 'SELECT * FROM `oc_appconfig`':\n\nSQLSTATE[42S02]: Base table or view not found: 1932 Table 'nextcloud16.oc_appconfig' doesn't exist in engine",{"errorInfo":["42S02",1932,"Table 'nextcloud16.oc_appconfig' doesn't exist in engine"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"}]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php","line":145,"function":"wrapException","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["42S02",1932,"Table 'nextcloud16.oc_appconfig' doesn't exist in engine"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"An exception occurred while executing 'SELECT * FROM `oc_appconfig`':\n\nSQLSTATE[42S02]: Base table or view not found: 1932 Table 'nextcloud16.oc_appconfig' doesn't exist in engine"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":911,"function":"driverExceptionDuringQuery","class":"Doctrine\\DBAL\\DBALException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"},{"errorInfo":["42S02",1932,"Table 'nextcloud16.oc_appconfig' doesn't exist in engine"],"__class__":"Doctrine\\DBAL\\Driver\\PDOException"},"SELECT * FROM `oc_appconfig`",[]]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[]]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":329,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":107,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":285,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":885,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/TemplateLayout.php","line":160,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/template.php","line":183,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["error",""]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/Template\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/template.php","line":332,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/index.php","line":69,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Exception\\DriverException"},500]}],"File":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":106,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1932 Table 'nextcloud16.oc_appconfig' doesn't exist in engine","Code":"42S02","Trace":[{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":908,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDOConnection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[]]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":329,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":107,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":285,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":885,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/TemplateLayout.php","line":160,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/template.php","line":183,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["error",""]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/Template\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/template.php","line":332,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/index.php","line":69,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Exception\\DriverException"},500]}],"File":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php","Line":90,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1932 Table 'nextcloud16.oc_appconfig' doesn't exist in engine","Code":"42S02","Trace":[{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php","line":88,"function":"query","class":"PDO","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Connection.php","line":908,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDOConnection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/Connection.php","line":195,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Query\/QueryBuilder.php","line":200,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[]]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/DB\/QueryBuilder\/QueryBuilder.php","line":214,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":329,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":107,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/AppConfig.php","line":285,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/app.php","line":885,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/TemplateLayout.php","line":160,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/template.php","line":183,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["error",""]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/Template\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/lib\/private\/legacy\/template.php","line":332,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"\/usr\/share\/nginx\/nextcloud16\/index.php","line":69,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Exception\\DriverException"},500]}],"File":"\/usr\/share\/nginx\/nextcloud16\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/PDOConnection.php","Line":88}},"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:82.0) Gecko\/20100101 Firefox\/82.0","version":"17.0.10.1"}
'instanceid' => 'ocyer84il00i',
'passwordsalt' => '1AjlbfbqfB5Sxjzazbdj1WRpknyd0J',
'secret' => '8PeHK1/BXN2Bzdm5HHRjHir0TAb+2uCz+RodVsuVXMhOGoXh',
0 => 'localhost',
'datadirectory' => '/usr/share/nginx/nextcloud-data',
'version' => '17.0.10.1',
'overwrite.cli.url' => 'http://nextcloud.eduardo.com',
'dbname' => 'nextcloud16',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'nextclouduser',
My old config.php:
'instanceid' => 'ocs55d73vvsx',
'passwordsalt' => 'hLXMybNoLWDQByjazQYcOMa5O+Pixr',
'secret' => '6CJXtgdGILbRlh49HH36SYI6YturQCmaz0dKi8sRGqhB9fly',
0 => 'nextcloud.eduardo.com',
1 => 'onlyoffice.eduardo.com',
2 => '192.168.1.51',
3 => '192.168.1.52',
'log_type' => 'file',
'logfile' => '/var/log/nextcloud16.log',
'logfilemode' => 416,
'loglevel' => '0',
'logdateformat' => 'F d, Y H:i:s',
'logtimezone' => 'Europe/Madrid',
'onlyoffice' =>
'jwt_header' => 'AuthorizationJwt',
'verify_peer_off' => true,
'theme' => '',
'updater.secret' => '$2y$10$a7gg//WG3zf8lsOCVml/4OEMbrgdEpHdSZHEQDyWbT2xjgu7E3CDy',
The access and error log:
Thanks
