Problem Creating and Editing Contacts
Hi. Is there a trick to doing this? I’m not having much success, TBH :frowning_face:
When I try and create a new contact, I get:
This contact is not yet synced. Edit it to save it to the server.
…but when I press RETURN, or TAB between fields, or hit refresh (etc.) it loses the information I’ve entered. (Sometimes - in the case of the display name - it loses everything except the first letter).
Likewise, if I edit an existing contact, the app loses many of the changes I make.
Am I doing something wrong?
P.S. Side issue: Sometimes it displays avatars from Gravatar; sometimes it doesn’t. And it’s weirdly unpredictable: I can’t work out what the common factors are :man_shrugging:
Any help gratefully received. Thank you.
Nextcloud 24.0.9
Contacts 4.2.4
Postgres 12.12
Did you find a solution for this?
My instance has the same issues :frowning:
