I can’t create a mail account to my server. The App want an account and a password for SMTP. I don’t use them because nextcloud and postfix are on the same computer and nobody from another computer is allow to connect to SMTP.
What can I do
Thank you
Benoit
The Nextcloud mail app is only a client application and doesn’t provide an email server. If you want to use the app you have to make sure that you use a valid email account
hello,
I understand that you say, but I have a postfix server. My problem is Nextcloud mail app doesn’t accept that I don’t use account to connect to my smtp. Is that normal, is there solution to modify?
Thank you
Benoit
The mail app needs an smtp and an imap server to work. That also requires username and password for both smtp and imap. So you need to configure postfix correctly and install an imap server as well if you want to use the mail app.
Thanks for reply.
For the imap, dovecot is working. I will changes parameters for the smtp.
Thank you
Benoit
This topic was automatically closed after 35 days. New replies are no longer allowed.
