Hi everyone,
so I updated to v15.0.2 getting the hint to convert database since I am using sqlite. Trying to do that in two different way, I get two different show stoppers.
Being in directory /var/www/html/nextcloud:
1. Using this command: php occ db:convert-type --all-apps mysql myusername 127.0.0.1 nc_database
ā> An unhandled exception has been thrown:
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred while executing āPRAGMA journal_mode = WALā:
SQLSTATE[HY000]: General error: 14 unable to open database file in /var/www/html/nextcloud/lib/private/DB/Connection.php:64
Stack trace:
#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(992): OC\DB\Connection->connect()
#1 /var/www/html/nextcloud/lib/private/DB/Connection.php(216): Doctrine\DBAL\Connection->executeUpdate(āPRAGMA read_uncā¦ā, Array, Array)
#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): OC\DB\Connection->executeUpdate(āPRAGMA read_uncā¦ā)
#3 /var/www/html/nextcloud/lib/private/DB/Connection.php(151): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#4 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOSqlite\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#5 /var/www/html/nextcloud/lib/private/DB/ConnectionFactory.php(158): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /var/www/html/nextcloud/lib/private/Server.php(641): OC\DB\ConnectionFactory->getConnection(āsqlite3ā, Array)
#7 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#8 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āOCP\IDBConnectiā¦ā)
#9 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āOCP\IDBConnectiā¦ā)
#10 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(āOCP\IDBConnectiā¦ā)
#11 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#12 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āDatabaseConnectā¦ā)
#13 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āDatabaseConnectā¦ā)
#14 /var/www/html/nextcloud/lib/private/Server.php(1552): OC\ServerContainer->query(āDatabaseConnectā¦ā)
#15 /var/www/html/nextcloud/lib/private/Server.php(360): OC\Server->getDatabaseConnection()
#16 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#17 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āOC\Authenticatiā¦ā)
#18 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āOC\Authenticatiā¦ā)
#19 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(68): OC\ServerContainer->query(āOC\Authenticatiā¦ā)
#20 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(98): OC\AppFramework\Utility\SimpleContainer->buildClass(Object(ReflectionClass))
#21 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(119): OC\AppFramework\Utility\SimpleContainer->resolve(āOC\Authenticatiā¦ā)
#22 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āOC\Authenticatiā¦ā)
#23 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(68): OC\ServerContainer->query(āOC\Authenticatiā¦ā)
#24 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(98): OC\AppFramework\Utility\SimpleContainer->buildClass(Object(ReflectionClass))
#25 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(119): OC\AppFramework\Utility\SimpleContainer->resolve(āOC\Authenticatiā¦ā)
#26 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āOC\Authenticatiā¦ā)
#27 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(āOC\Authenticatiā¦ā)
#28 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#29 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āOC\Authenticatiā¦ā)
#30 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āOC\Authenticatiā¦ā)
#31 /var/www/html/nextcloud/lib/private/Server.php(372): OC\ServerContainer->query(āOC\Authenticatiā¦ā)
#32 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#33 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āOC\User\Sessionā)
#34 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āOC\User\Sessionā)
#35 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(āOC\User\Sessionā)
#36 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#37 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āUserSessionā)
#38 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āUserSessionā)
#39 /var/www/html/nextcloud/lib/private/Server.php(1428): OC\ServerContainer->query(āUserSessionā)
#40 /var/www/html/nextcloud/lib/private/Server.php(694): OC\Server->getUserSession()
#41 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#42 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āOC\App\AppManagā¦ā)
#43 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āOC\App\AppManagā¦ā)
#44 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(āOC\App\AppManagā¦ā)
#45 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#46 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(āAppManagerā)
#47 /var/www/html/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(āAppManagerā)
#48 /var/www/html/nextcloud/lib/private/Server.php(1723): OC\ServerContainer->query(āAppManagerā)
#49 /var/www/html/nextcloud/lib/private/legacy/app.php(342): OC\Server->getAppManager()
#50 /var/www/html/nextcloud/lib/private/legacy/app.php(113): OC_App::getEnabledApps()
#51 /var/www/html/nextcloud/lib/base.php(654): OC_App::loadApps(Array)
#52 /var/www/html/nextcloud/lib/base.php(1068): OC::init()
#53 /var/www/html/nextcloud/console.php(46): require_once(ā/var/www/html/nā¦ā)
#54 /var/www/html/nextcloud/occ(11): require_once(ā/var/www/html/nā¦ā)
2. Using this command: sudo -u www-data php occ db:convert-type --all-apps mysql myusername 127.0.0.1 nc_database
ā> What is the database password? What password? I don not have a sqlite db password.
In Connection.php line 64:
Failed to connect to the database: An exception occured in driver: could not find driver
db:convert-type [āport PORT] [āpassword PASSWORD] [āclear-schema] [āall-apps] [āchunk-size CHUNK-SIZE] [ā]
Can you help? There is no post in this forum or the www as I searched to help me out. Or I am just to blind to handle.
Thank you in advance.
