Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
Nextcloud version (eg, 20.0.5): 20
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.25
PHP version (eg, 7.4): 7.4
Nach der Verschiebung auf einen anderen Server zeigt mir die Cloud diesen Fehler:
Imgur: The magic of the Internet. Wenn ich die 770 Berechtigungen zuweise, kommt aber dass nicht auf die ocdata zugegriffen werden kann.
Is this the first time youâve seen this error? (Y/N): Y
Kann ich nicht einsehen
'passwordsalt' => 'xxx/1A4zj4I/',
'secret' => 'xxx',
0 => 'localhost',
1 => 'cloud.domain.de',
2 => 'www.cloud.domain.de',
'datadirectory' => '/var/www/vhosts/cloud.domain.de/httpdocs/userdata',
'version' => '21.0.1.1',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'xx',
'dbhost' => 'localhost',
'dbport' => '3306',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'instanceid' => 'ocpw6lgp9iip',
'force_language' => 'de',
'force_locale' => 'de_DE',
'skeletondirectory' => '/var/www/vhosts/cloud.domain.de/httpdocs/data/sk',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_domain' => 'domain.de',
'mail_smtpauth' => 1,
'mail_smtpname' => 'cloud@domain.de',
'mail_smtppassword' => 'Ckd3v48$',
'mail_smtphost' => 'domain.de',
'mail_smtpport' => '465',
n.a.
