Nextcloud version 20.0.0
Operating system and version Unraid Nextcloud docker
Apache or nginx version: Nginx
PHP version : 7.3.23
If I try to assign a user to a card in Desk it will not add it. At first it will add the user (round icon) but if I close the card details and enter them again this never saves/gets assigned.
Is this the first time you’ve seen this error?: No or yes - its been like this since new install.
- Add a new card in Desk in a shared board
- Assign a user
- The user assignment will not save/stick
[PHP] Error: Error: Undefined offset: 3 at /config/www/nextcloud/lib/private/legacy/OC_Helper.php#548 at <<closure>>
0. /config/www/nextcloud/lib/private/legacy/OC_Helper.php line 548
OC\Log\ErrorHandler::onError(8, "Undefined offset: 3", "/config/www/nex ... p", 548, {path: "/",rootI ... }})
1. /config/www/nextcloud/apps/settings/lib/Settings/Personal/PersonalInfo.php line 108
OC_Helper::getStorageInfo("/")
2. /config/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php line 141
OCA\Settings\Settings\Personal\PersonalInfo->getForm()
3. /config/www/nextcloud/apps/settings/lib/Controller/PersonalSettingsController.php line 77
OCA\Settings\Controller\PersonalSettingsController->formatSettings({10: [OCA\Settin ... ]})
4. /config/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php line 152
OCA\Settings\Controller\PersonalSettingsController->getSettings("personal-info")
5. /config/www/nextcloud/apps/settings/lib/Controller/PersonalSettingsController.php line 68
OCA\Settings\Controller\PersonalSettingsController->getIndexResponse("personal", "personal-info")
6. /config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 169
OCA\Settings\Controller\PersonalSettingsController->index("personal-info")
7. /config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 100
OC\AppFramework\Http\Dispatcher->executeController(OCA\Settings\Con ... {}, "index")
8. /config/www/nextcloud/lib/private/AppFramework/App.php line 152
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Settings\Con ... {}, "index")
9. /config/www/nextcloud/lib/private/Route/Router.php line 308
OC\AppFramework\App::main("OCA\\Settings\\ ... r", "index", OC\AppFramework\ ... {}, {section: "perso ... "})
10. /config/www/nextcloud/lib/base.php line 1009
OC\Route\Router->match("/settings/user")
11. /config/www/nextcloud/index.php line 37
OC::handleRequest()
GET /settings/user
from 188.126.94.70 by claes at 2020-10-23T12:59:24+00:00
