i just recently did the update to the latest version, via the command line. As it looked fine, i did a reboot and now iām running in some serious problems.
When i try to access my cloud, i get the message that the data dir is incorrect. Also, when i try to access the NextcloudPi Webpanel, it tellās me āUnauthorized request. Try reloading the pageā on every single option of the interface.
When iām going to the mounted dir of my external hdd, there are no more files in it. Maybe itās not mounted anymore? The hdd still shows up in fdisk.
Really could use some help, as iām not the most experienced linux user
okay, i think the update has destroyed the mounting processā¦ when i type āsystemctl status nc-automountā, i get the following output:
pi@cloudserver:/media $ systemctl status nc-automount
ā nc-automount.service - Automount USB drives
Loaded: loaded (/usr/lib/systemd/system/nc-automount.service; enabled)
Active: failed (Result: start-limit) since Do 2017-09-21 04:48:09 CEST; 1min 12s ago
Process: 590 ExecStart=/usr/bin/udiskie -NTF (code=exited, status=203/EXEC)
Main PID: 590 (code=exited, status=203/EXEC)
EDIT: when i mount the drive manually using āsudo mount -t ext4 /dev/sda1 /media/USBdriveā, the files are showing up again and the cloud is useable again. But the problem with the webinterface and automount still persists. Telling me āread errorā.
Indeed, i have touched absolutly nothing at the server configuration.
The outputs are:
head: ā/usr/bin/udiskieā kann nicht zum Lesen geƶffnet werden: Datei oder Verzeichnis nicht gefunden
(Translation: ādirā cannot be opened for reading. File or folder not found)
udiskie --help:
-bash: udiskie: Kommando nicht gefunden.
(Translation: command not found)
python3 /usr/bin/udiskie --help
python3: canāt open file ā/usr/bin/udiskieā: [Errno 2] No such file or directory
So it really looks like, there is no plugin called āudiskieā, but as i said, i did not touch the standard configuration at allā¦
Sorry for my delayā¦ University just started recently. If i run the update command, i get the following output (as my pi is configured in german, you might use a translator):
pi@cloudserver:~ $ sudo ncp-update
Downloading updates
Performing updates
Installing nc-automount
Holen:1 http://archive.raspberrypi.org/debian jessie InRelease [22,9 kB]
OK:2 http://mirrordirector.raspbian.org/raspbian jessie InRelease
OK:3 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Es wurden 22,9 kB in 1 s geholt (15,1 kB/s).
Paketlisten werden gelesenā¦ Fertig
AbhƤngigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesenā¦ Fertig
Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
Sie eine unmƶgliche Situation angefordert haben oder, wenn Sie die
Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
nicht erstellt wurden oder Incoming noch nicht verlassen haben.
Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lƶsen:
Die folgenden Pakete haben unerfĆ¼llte AbhƤngigkeiten:
udiskie : HƤngt ab von: python3-gi soll aber nicht installiert werden
HƤngt ab von: python3-yaml soll aber nicht installiert werden
E: Probleme kƶnnen nicht korrigiert werden, Sie haben zurĆ¼ckgehaltene defekte Pakete.
Activating unattended-upgrades
Unattended upgrades active: yes (autoreboot yes)
NextCloudPi updated to version v0.31.14
The following packages have unfulfilled dependencies:
udiskie: depends on python3-gi, but should not be installed
Depends on: python3-yaml, but should not be installed
E: problems could not be corrected, they have restrained packages.
Original:
It might not be 100% translated correctly, but i think you can work with it
Iām facing, that i maybe have to do a clean reinstall of the system. Can you tell me if there is a guide to do this, with backing up the old state? Because i really donāt want to reconfigure the hole user structure etc., that would be a pain in the ass :D. And should rescan the files from the connected ext hdd.
Unfortunately, I donāt have a solution for your problem directly, but if you wind up having to reinstall, it should be reasonably straightforward; there is a guide for migrating an NC instance (which is essentially what youād be doing) here:
This should allow you to move your entire NC installation to a new host. You shouldnāt have to worry about the DNS stuff as long as you have a fresh NCP installation on the same physical machine, and make sure the name on the local network is the same (e.g., ānextcloudpiā, or āraspberrypiā). Itās not pain-free, but it should be a lot easier than having to rebuild your NC installation from scratch.
Hi, I suggest you do a nc-backup and then you can restore it in the new image with nc-restore.
That way it will be easy to start from a new clean image.
You will have to do all the stuff again for NCP, such as automount, letsencrypt, DDNS, nc-datadir but Nextcloud you can just restore it in the new instance.
