Nextcloud version: 23.0.0
Operating system and version: Ubuntu 20.04
mysql 10.5.13
PHP version: 7.4
Is this the first time you’ve seen this error? Y
After Updating to Nextcloud 23.0.0 we can not delete any users at all.
Currently, we do not have any idea to solve the problem.
Your help is appreciated.
{"reqId":"9EGFxEuMY4hlLJAkfuth","level":3,"time":"2022-01-13T07:41:50+00:00","remoteAddr":"10.145.xxx.xxx","user":"admin","app":"no app in context","method":"DELETE","url":"/nextcloud/ocs/v2.php/cloud/users/asdf12234","message":"path needs to be relative to the system wide data folder and point to a user specific file","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36 Edg/97.0.1072.55","version":"23.0.0.10","exception":{"Exception":"BadMethodCallException","Message":"path needs to be relative to the system wide data folder and point to a user specific file","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Encryption/Keys/Storage.php","line":367,"function":"getUidAndFilename","class":"OC\\Encryption\\Util","type":"->"},{"file":"/var/www/nextcloud/lib/private/Encryption/Keys/Storage.php","line":189,"function":"getFileKeyDir","class":"OC\\Encryption\\Keys\\Storage","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Encryption.php","line":315,"function":"deleteAllFileKeys","class":"OC\\Encryption\\Keys\\Storage","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":94,"function":"rmdir","class":"OC\\Files\\Storage\\Wrapper\\Encryption","type":"->"},{"function":"rmdir","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/files_trashbin/lib/Storage.php","line":193,"function":"call_user_func"},{"file":"/var/www/nextcloud/apps/files_trashbin/lib/Storage.php","line":125,"function":"doDelete","class":"OCA\\Files_Trashbin\\Storage","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":94,"function":"rmdir","class":"OCA\\Files_Trashbin\\Storage","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Listeners/UserDeletedFilesCleanupListener.php","line":72,"function":"rmdir","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php","line":87,"function":"handle","class":"OC\\Authentication\\Listeners\\UserDeletedFilesCleanupListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":251,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":88,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":100,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/User/User.php","line":301,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/apps/provisioning_api/lib/Controller/UsersController.php","line":1068,"function":"delete","class":"OC\\User\\User","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":217,"function":"deleteUser","class":"OCA\\Provisioning_API\\Controller\\UsersController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":126,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":157,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":62,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":23,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Encryption/Util.php","Line":233,"CustomMessage":"--"}}
