Hi, I’m having some problems to access my nextcloud using https.
I have installed it using docker and throug the http protocol I have no problem to access it, i made a dns record using no-ip and if I try to access through the web using the ip address it works (and it uses the http protocol) but if i try to access it using the name that i gave to my domain it shows a php file like this:
* @copyright Copyright (c) 2016, ownCloud, Inc.
* @author Christoph Wurst <christoph@winzerhof-wurst.at>
* @author Joas Schilling <coding@schilljs.com>
* @author Jörn Friedrich Dreyer <jfd@butonic.de>
* @author Lukas Reschke <lukas@statuscode.ch>
* @author Morris Jobke <hey@morrisjobke.de>
* @author Robin Appelman <robin@icewind.nl>
* @author Roeland Jago Douma <roeland@famdouma.nl>
* @author Sergio BertolÃn <sbertolin@solidgear.es>
* @author Thomas Müller <thomas.mueller@tmit.eu>
* @author Vincent Petry <vincent@nextcloud.com>
* @license AGPL-3.0
* This code is free software: you can redistribute it and/or modify
* it under the terms of the GNU Affero General Public License, version 3,
* as published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Affero General Public License for more details.
* You should have received a copy of the GNU Affero General Public License, version 3,
* along with this program. If not, see <http://www.gnu.org/licenses/>
require_once __DIR__ . '/lib/versioncheck.php';
try {
require_once __DIR__ . '/lib/base.php';
OC::handleRequest();
} catch (\OC\ServiceUnavailableException $ex) {
\OC::$server->getLogger()->logException($ex, ['app' => 'index']);
//show the user a detailed error page
OC_Template::printExceptionErrorPage($ex, 503);
} catch (\OC\HintException $ex) {
try {
OC_Template::printErrorPage($ex->getMessage(), $ex->getHint(), 503);
} catch (Exception $ex2) {
try {
\OC::$server->getLogger()->logException($ex2, ['app' => 'index']);
} catch (Throwable $e) {
// no way to log it properly - but to avoid a white page of death we try harder and ignore this one here
OC_Template::printExceptionErrorPage($ex, 500);
} catch (\OC\User\LoginException $ex) {
$request = \OC::$server->getRequest();
* Routes with the @CORS annotation and other API endpoints should
* not return a webpage, so we only print the error page when html is accepted,
* otherwise we reply with a JSON array like the SecurityMiddleware would do.
if (stripos($request->getHeader('Accept'),'html') === false) {
http_response_code(401);
header('Content-Type: application/json; charset=utf-8');
echo json_encode(['message' => $ex->getMessage()]);
exit();
OC_Template::printErrorPage($ex->getMessage(), $ex->getMessage(), 401);
} catch (Exception $ex) {
} catch (Error $ex) {
try {
} catch (Error $e) {
http_response_code(500);
header('Content-Type: text/plain; charset=utf-8');
print("Internal Server Error\n\n");
print("The server encountered an internal error and was unable to complete your request.\n");
print("Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.\n");
print("More details can be found in the webserver log.\n");
throw $ex;
I use apache and i made a virtual host, i also have used letsencrypt for the ssl certificate.
Using docker i binded my folder to an external hdd (mounted on /mnt/disk1) where i have 3 folders: html, data and mariadb. Is this the right document root for the virtual host file configuration?
In my sites available (apache2/sites-available) i got nextcloud.conf and nextcloud-le-ssl.conf files where i put the info about my domain and my document root folder.
This is my nextcloud-le-ssl.conf file
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerAdmin email@pm.me
DocumentRoot /mnt/disk1/html
ServerName noipaddress.zapto.org
ServerAlias www.noipaddress.zapto.org
Alias /nextcloud "/mnt/disk1/html"
<Directory /mnt/disk1/html>
Options +FollowSymlinks
AllowOverride All
Require all granted
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /mnt/disk1/html
SetEnv HTTP_HOME /mnt/disk1/html
</Directory>
SSLCertificateFile /etc/letsencrypt/live/noipaddress.zapto.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/noipaddress.zapto.org/privkey.pem
</VirtualHost>
</IfModule>
I also added to config.php the trusted domains
