Pia
November 9, 2021, 4:05pm
#1
I’m looking for a way to preview PDF files and then by clicking right on keyboard it takes you to the next PDF file (not next page), like you can do in Google Drive as well. I have a lot of PDF files I need to check 1-by-1 and it would just make my life easier to be able to click right instead of open and close each file. Hope it makes sense!
Thanks in advance for any help on this!
devnull
November 10, 2021, 3:53pm
#2
I think it is not possible. But you can use Tiny File Manager
Example:
https://tinyfilemanager.github.io/demo/
Click on the eye on the right sight (Actions).
Tiny File Manager is a one file (tinyfilemanager.php) filemanager.
The pdf viewer (Javascript) is loaded from CDN (Google).
szaimen
November 10, 2021, 4:26pm
#3
There is an issue where this gets discussed but no decision was made, yet:
opened 03:54PM - 12 Jul 21 UTC
enhancement
needs info
0. Needs triage
### Steps to reproduce
1. Enable Files viewer and Pdf viewer apps
2. Navigate … to folder of PDFs
3. Open PDF in viewer lightbox
### Expected behaviour
(More desired than expected behavior) Utilize same left/right controls that files viewer uses for photos/videos.
### Actual behaviour
No controls, can only open a single PDF at a time.
### Server configuration
**Operating system**:
Debian
**Web server:**
Apache2
**Database:**
MySql 10.3.30
**PHP version:**
7.4.19
**Nextcloud version:** (see Nextcloud admin page)
21.0.2
**Where did you install Nextcloud from:**
cloudamo script
(Excluding the rest of the info, as this is not an issue, but a feature request.)
Is this feature request a possibility? I understand from reading the initial issue submitted for this app to use nextcloud/viewer there may be limitations.
