NC = 19.0.6
Preview Generator = 2.3.0
PHP = 7.3.21
My Preview Generator Pre-run
./occ preview:generate-all -vvv
terminated after 12 hrs. succesfully.
I’m adviced to add this to my system cron:
php /var/www/nextcloud/occ preview:pre-generate.
To test the validity / outcome of the above, I issue:
sudo -u www-data php /var/www/nextcloud/occ preview:pre-generate
in my terminal, and receive this error list:
Error: Call to a member function file_get_contents() on null in /var/www/nextcloud/lib/private/Files/Filesystem.php:715
Stack trace:
#0 /var/www/nextcloud/lib/private/legacy/OC_Image.php(624): OC\Files\Filesystem::file_get_contents(’/nc_data/Derber…’)
#1 /var/www/nextcloud/lib/private/Preview/Image.php(52): OC_Image->loadFromFile(’/nc_data/Derber…’)
#2 /var/www/nextcloud/lib/private/Preview/GeneratorHelper.php(63): OC\Preview\Image->getThumbnail(Object(OC\Files\Node\File), 1024, 768)
#3 /var/www/nextcloud/lib/private/Preview/Generator.php(241): OC\Preview\GeneratorHelper->getThumbnail(Object(OC\Preview\JPEG), Object(OC\Files\Node\File), 1024, 768)
#4 /var/www/nextcloud/lib/private/Preview/Generator.php(141): OC\Preview\Generator->getMaxPreview(Object(OC\Files\SimpleFS\SimpleFolder), Object(OC\Files\Node\File), ‘image/jpeg’, ‘’)
#5 /var/www/nextcloud/lib/private/Preview/Generator.php(107): OC\Preview\Generator->generatePreviews(Object(OC\Files\Node\File), Array, ‘image/jpeg’)
#6 /var/www/nextcloud/lib/private/PreviewManager.php(190): OC\Preview\Generator->getPreview(Object(OC\Files\Node\File), 32, 32, true, ‘fill’, NULL)
#7 /var/www/nextcloud/apps/previewgenerator/lib/Command/PreGenerate.php(205): OC\PreviewManager->getPreview(Object(OC\Files\Node\File), 32, 32, true)
#8 /var/www/nextcloud/apps/previewgenerator/lib/Command/PreGenerate.php(193): OCA\PreviewGenerator\Command\PreGenerate->processFile(Object(OC\Files\Node\File))
#9 /var/www/nextcloud/apps/previewgenerator/lib/Command/PreGenerate.php(164): OCA\PreviewGenerator\Command\PreGenerate->processRow(Array)
#10 /var/www/nextcloud/apps/previewgenerator/lib/Command/PreGenerate.php(132): OCA\PreviewGenerator\Command\PreGenerate->startProcessing()
#11 /var/www/nextcloud/3rdparty/symfony/console/Command/Command.php(255): OCA\PreviewGenerator\Command\PreGenerate->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#12 /var/www/nextcloud/3rdparty/symfony/console/Application.php(1012): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#13 /var/www/nextcloud/3rdparty/symfony/console/Application.php(272): Symfony\Component\Console\Application->doRunCommand(Object(OCA\PreviewGenerator\Command\PreGenerate), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#14 /var/www/nextcloud/3rdparty/symfony/console/Application.php(148): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#15 /var/www/nextcloud/lib/private/Console/Application.php(215): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#16 /var/www/nextcloud/console.php(100): OC\Console\Application->run()
#17 /var/www/nextcloud/occ(11): require_once(’/var/www/nextcl…’)
what can I do? Any advice
Thank you
