example
longer
example
here
Nextcloud version (eg, 20.0.5): 24.0.9
Operating system and version (eg, Ubuntu 20.04): debian 11 bullseye
Apache or nginx version (eg, Apache 2.4.25): Apache
PHP version (eg, 7.4): PHP 7.4.33
The file ctime
is changed after uploading with desktop client Version 3.7.3 on Manjaro. This causes error messages when editing a file with neovim.
Is this the first time you’ve seen this error? (Y/N): I have seen it repeatedly after I started using neovim a lot in the last days.
- Pause sync
- Create a file and edit it in neovim:
nvim test.md
. Keep some unsaved changes. - Check ctime:
ls -lc test.md
- wait for a few minutes, then enable sync
- after the file is edited, nvim will show W12 (
Warning: File "{filename}" has changed and the buffer was changed in Vim as well
As long as the nextcloud sync is disabled, I don’t see this error.
How can I present this behaviour? Can I disable an option to avoid changing the ctime?
