The manual says:
The default configuration for PostgreSQL (at least in Ubuntu 14.04) is to use the peer
authentication method. Check /etc/postgresql/10/main/pg_hba.conf to find out which
authentication method is used in your setup.
I tried several settings but none is working.
I added the following line
local nextcloud www-data peer
so the linux user www-data can access the postgres db nextcloud
without password.
But running occ maintenance:install
fails
sudo -u www-data php /var/www/nextcloud/occ maintenance:install --database pgsql --database-host "/var/run/postgresql" \
--database-name nextcloud --database-table-prefix oc_ --database-user nextcloud \
--database-pass "" --admin-user admin --admin-pass JejV9RYQUI5o250PQJyJZesAOQKgJguv \
--data-dir /var/nc-data
Error while trying to create admin user: Failed to connect to the database: An exception occurred in driver: SQLSTATE[08006] [7] FATAL: Peer authentication failed for user "nextcloud"
Does anyone knows a working setup?
P.S.:
