30.0.4
Ubuntu 24.04.1 LTS
Apache/2.4.62 (Debian)
nginx-proxy-manager v2.12.2
- PHP version (e.g, 8.3):
8.2.27
yes
unsure, only noticed today
official Nextcloud Docker image
no
My setup used to be the AIO Docker setup but it didn’t work out for me, so i’m managing the containers myself now and that’s why i’m using the nextcloud/aio-postgresql
image for my database instead of e.g. regular postgres.
Every 30 seconds, this line gets logged in my nextcloud/aio-postgresql
container:
nextcloud_database | 2025-04-02 17:40:54.032 UTC [123] FATAL: role "oc_" does not exist
Nextcloud seems to work normally, i have not encountered any usage issues or errors in the web interface.
don’t know, sorry
(this is the same line as in the summary)
n/a
unsure which one’s to post and i hope they are not applicable to this issue regardless
The output of occ config:list system
or similar is best, but, if not possible, the contents of your config.php
file from /path/to/nextcloud
is fine (make sure to remove any identifiable information!):
"default_phone_region": "DE",
"overwrite.cli.url": "https:\/\/cloud.bunker496.de",
"overwriteprotocol": "https",
"redis": {
"port": 6379
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"int.bunker496.de",
"cloud.bunker496.de",
"localhost"
"dbtype": "pgsql",
"version": "30.0.4.1",
"app_install_overwrite": [
"nextcloud-aio"
"upgrade.disable-web": true,
"activity_expire_days": 30,
"share_folder": "\/Shared",
"htaccess.RewriteBase": "\/",
"dbpersistent": false,
"mail_smtpport": "465",
"mail_smtpauth": 1,
"forbidden_filename_basenames": [
"con",
"prn",
"aux",
"nul",
"com0",
"com1",
"com2",
"com3",
"com4",
"com5",
"com6",
"com7",
"com8",
"com9",
"com\u00b9",
"com\u00b2",
"com\u00b3",
"lpt0",
"lpt1",
"lpt2",
"lpt3",
"lpt4",
"lpt5",
"lpt6",
"lpt7",
"lpt8",
"lpt9",
"lpt\u00b9",
"lpt\u00b2",
"lpt\u00b3"
"forbidden_filename_characters": [
"forbidden_filename_extensions": [
".filepart",
".part"
"config_is_read_only": false,
"one-click-instance": true,
"maintenance": false
"apps": {
"activity": {
"types": "filesystem",
"enabled": "yes",
"installed_version": "3.0.0"
"admin_audit": {
"installed_version": "1.20.0",
"types": "logging",
"enabled": "yes",
"logfile": "\/var\/www\/html\/data\/audit.log"
"app_api": {
"default_daemon_config": "docker_aio",
"types": "",
"enabled": "yes",
"installed_version": "4.0.3"
"backgroundjob": {
"lastjob": "190"
"bruteForce": {
"whitelist_1": "192.168.178.0\/24"
"bruteforcesettings": {
"installed_version": "3.0.0",
"types": "",
"enabled": "yes"
"calendar": {
"types": "",
"enabled": "yes",
"installed_version": "5.2.0"
"circles": {
"types": "filesystem,dav",
"enabled": "yes",
"installed_version": "30.0.0",
"migration_22": "1",
"migration_run": "0",
"loopback_tmp_path": "\/",
"loopback_tmp_scheme": "https",
"maintenance_run": "0",
"maintenance_update": "{\"3\":1743615002,\"2\":1743615902,\"1\":1743616201}"
"cloud_federation_api": {
"enabled": "yes",
"installed_version": "1.13.0"
"comments": {
"types": "logging",
"enabled": "yes",
"installed_version": "1.20.1"
"contacts": {
"types": "dav",
"enabled": "no",
"installed_version": "7.0.4",
"allowSocialSync": "yes"
"contactsinteraction": {
"types": "dav",
"enabled": "yes",
"installed_version": "1.11.0"
"core": {
"vendor": "nextcloud",
"lastupdatedat": 0,
"public_files": "files_sharing\/public.php",
"moveavatarsdone": "yes",
"previewsCleanedUp": "1",
"installedat": "1731687725.9300",
"backgroundjobs_mode": "cron",
"emailTestSuccessful": "1",
"metadataGenerationDone": true,
"lastcron": 1743616201,
"files_metadata": {
"photos-original_date_time": {
"value": null,
"type": "int",
"etag": "",
"indexed": true,
"editPermission": 0
"photos-size": {
"value": null,
"type": "array",
"etag": "",
"indexed": false,
"editPermission": 0
"photos-exif": {
"value": null,
"type": "array",
"etag": "",
"indexed": false,
"editPermission": 0
"photos-ifd0": {
"value": null,
"type": "array",
"etag": "",
"indexed": false,
"editPermission": 0
"blurhash": {
"value": null,
"type": "string",
"etag": "ba23c4c7936e390a648c8d27a4d7c20a",
"indexed": false,
"editPermission": 0
"oc.integritycheck.checker": []
"dashboard": {
"types": "",
"enabled": "yes",
"installed_version": "7.10.0"
"dav": {
"enabled": "yes",
"installed_version": "1.31.1",
"regeneratedBirthdayCalendarsForYearFix": "yes",
"buildCalendarSearchIndex": "yes",
"buildCalendarReminderIndex": "yes",
"chunks_migrated": "1",
"builtSocialSearchIndex": "yes"
"deck": {
"types": "dav",
"enabled": "no",
"installed_version": "1.14.4"
"federatedfilesharing": {
"types": "",
"enabled": "yes",
"federation": {
"types": "authentication",
"enabled": "no"
"files": {
"enabled": "yes",
"installed_version": "2.2.0",
"mimetype_version": "30.0.4.1",
"default_quota": "100 GB"
"files_downloadlimit": {
"types": "",
"enabled": "yes",
"default-download-limit": 1
"files_fulltextsearch": {
"enabled": "no",
"files_pdf": "1",
"files_office": "1",
"installed_version": "31.0.0"
"files_pdfviewer": {
"types": "",
"enabled": "yes",
"files_reminders": {
"types": "",
"enabled": "yes",
"installed_version": "1.3.0"
"files_sharing": {
"enabled": "yes",
"installed_version": "1.22.0"
"files_trashbin": {
"enabled": "yes",
"files_versions": {
"enabled": "yes",
"installed_version": "1.23.0"
"firstrunwizard": {
"types": "logging",
"enabled": "yes",
"fulltextsearch": {
"types": "",
"search_platform": "OCA\\FullTextSearch_Elasticsearch\\Platform\\ElasticSearchPlatform",
"enabled": "no",
"installed_version": "30.0.1",
"cron_err_reset": "1740955803"
"fulltextsearch_elasticsearch": {
"enabled": "no",
"types": "",
"elastic_host": "http:\/\/elastic:b236d11e13330b026fb518f13239b6b24f16d19047806a6a@nextcloud-aio-fulltextsearch:9200",
"elastic_index": "nextcloud-aio",
"geoblocker": {
"installed_version": "0.5.16",
"types": "",
"enabled": "yes",
"chosenService": "3"
"group_everyone": {
"installed_version": "0.1.17",
"enabled": "yes"
"groupfolders": {
"installed_version": "18.1.2",
"enabled": "yes"
"logreader": {
"types": "logging",
"enabled": "yes",
"lookup_server_connector": {
"enabled": "yes",
"installed_version": "1.18.0"
"nextcloud-aio": {
"types": "",
"enabled": "yes",
"installed_version": "0.7.0"
"nextcloud_announcements": {
"types": "logging",
"enabled": "yes",
"installed_version": "2.0.0",
"pub_date": "Thu, 24 Oct 2019 00:00:00 +0200"
"notes": {
"installed_version": "4.11.0",
"types": "",
"enabled": "no"
"notifications": {
"types": "logging",
"enabled": "yes",
"notify_push": {
"installed_version": "1.0.0",
"enabled": "no",
"base_endpoint": "https:\/\/cloud.bunker496.de\/push",
"cookie": "***REMOVED SENSITIVE VALUE***"
"oauth2": {
"enabled": "yes",
"installed_version": "1.18.1"
"password_policy": {
"enabled": "yes",
"enforceNumericCharacters": "1",
"minLength": "16",
"historySize": "5",
"expiration": "365",
"maximumLoginAttempts": "5",
"enforceUpperLowerCase": "1"
"photos": {
"types": "dav,authentication",
"enabled": "yes",
"installed_version": "3.0.2",
"lastPlaceMappedUser": "admin",
"lastPlaceMappingDone": "true"
"preview": {
"jpeg_quality": "60"
"privacy": {
"types": "",
"enabled": "yes",
"readableLocation": "de"
"provisioning_api": {
"types": "prevent_group_restriction",
"enabled": "yes",
"recommendations": {
"types": "",
"enabled": "yes",
"related_resources": {
"types": "",
"enabled": "yes",
"installed_version": "1.5.0"
"richdocuments": {
"wopi_allowlist": "77.22.100.50,127.0.0.1\/8,192.168.0.0\/16,172.16.0.0\/12,10.0.0.0\/8,fd00::\/8,::1,95.33.213.171,95.33.210.14,95.33.193.93,95.33.212.44",
"installed_version": "8.5.6",
"wopi_url": "https:\/\/cloud.bunker496.de\/",
"enabled": "no",
"wopi_callback_url": "",
"public_wopi_url": "https:\/\/cloud.bunker496.de"
"serverinfo": {
"types": "",
"enabled": "yes",
"cached_count_filecache": "3510",
"cached_count_storages": "5",
"token": "***REMOVED SENSITIVE VALUE***"
"settings": {
"types": "",
"enabled": "yes",
"installed_version": "1.13.0",
"profile_enabled_by_default": "0"
"sharebymail": {
"enabled": "yes",
"sociallogin": {
"types": "",
"installed_version": "5.9.2",
"disable_registration": "",
"create_disabled_users": "1",
"allow_login_connect": "1",
"prevent_create_email_exists": "1",
"no_prune_user_groups": "",
"auto_create_groups": "1",
"restrict_users_wo_mapped_groups": "",
"restrict_users_wo_assigned_groups": "",
"disable_notify_admins": "",
"update_profile_on_login": "1",
"enabled": "yes",
"hide_default_login": "",
"button_text_wo_prefix": "",
"custom_providers": "null",
"oauth_providers": "{\"google\":{\"appid\":\"816474586682-vg4g97vq33ic1amrhftsac52q1pip0tm.apps.googleusercontent.com\",\"secret\":\"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\",\"defaultGroup\":\"\",\"auth_params\":{\"hd\":\"\"}},\"discord\":{\"appid\":\"1307036611875442768\",\"secret\":\"CW99h3ISU7L9iF38Hv-lqaDq4uN3jtJo\",\"defaultGroup\":\"\",\"guilds\":\"\"}}"
"spreed": {
"turn_servers": "***REMOVED SENSITIVE VALUE***",
"stun_servers": "***REMOVED SENSITIVE VALUE***",
"types": "dav,prevent_group_restriction",
"signaling_servers": "***REMOVED SENSITIVE VALUE***",
"enabled": "no",
"installed_version": "20.1.5",
"project_access_invalidated": "1",
"signaling_token_privkey_es256": "***REMOVED SENSITIVE VALUE***",
"signaling_token_pubkey_es256": "***REMOVED SENSITIVE VALUE***"
"support": {
"types": "session",
"enabled": "yes",
"SwitchUpdaterServerHasRun": "yes"
"survey_client": {
"types": "",
"enabled": "yes",
"last_sent": "1743591607",
"last_report": "{\"id\":\"oc4m7eyezz6w\",\"items\":[[\"server\",\"version\",\"30.0.4.1\"],[\"server\",\"code\",\"other\"],[\"server\",\"enable_avatars\",\"yes\"],[\"server\",\"enable_previews\",\"yes\"],[\"server\",\"memcache.local\",\"\\\\OC\\\\Memcache\\\\APCu\"],[\"server\",\"memcache.distributed\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"asset-pipeline.enabled\",\"no\"],[\"server\",\"filelocking.enabled\",\"yes\"],[\"server\",\"memcache.locking\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"debug\",\"no\"],[\"server\",\"cron\",\"cron\"],[\"php\",\"version\",\"8.2.27\"],[\"php\",\"memory_limit\",2147483648],[\"php\",\"max_execution_time\",0],[\"php\",\"upload_max_filesize\",214748364800],[\"database\",\"type\",\"pgsql\"],[\"database\",\"version\",\"PostgreSQL 16.6 on x86_64-pc-linux-musl, compiled by gcc (Alpine 14.2.0) 14.2.0, 64-bit\"],[\"database\",\"size\",44020195],[\"apps\",\"lookup_server_connector\",\"1.18.0\"],[\"apps\",\"oauth2\",\"1.18.1\"],[\"apps\",\"password_policy\",\"2.0.0\"],[\"apps\",\"files\",\"2.2.0\"],[\"apps\",\"activity\",\"3.0.0\"],[\"apps\",\"circles\",\"30.0.0\"],[\"apps\",\"cloud_federation_api\",\"1.13.0\"],[\"apps\",\"dav\",\"1.31.1\"],[\"apps\",\"files_trashbin\",\"1.20.1\"],[\"apps\",\"files_versions\",\"1.23.0\"],[\"apps\",\"sharebymail\",\"1.20.0\"],[\"apps\",\"workflowengine\",\"2.12.0\"],[\"apps\",\"comments\",\"1.20.1\"],[\"apps\",\"firstrunwizard\",\"3.0.0\"],[\"apps\",\"logreader\",\"3.0.0\"],[\"apps\",\"nextcloud_announcements\",\"2.0.0\"],[\"apps\",\"notifications\",\"3.0.0\"],[\"apps\",\"systemtags\",\"1.20.0\"],[\"apps\",\"theming\",\"2.5.0\"],[\"apps\",\"dashboard\",\"7.10.0\"],[\"apps\",\"federatedfilesharing\",\"1.20.0\"],[\"apps\",\"files_downloadlimit\",\"3.0.0\"],[\"apps\",\"files_pdfviewer\",\"3.0.0\"],[\"apps\",\"files_reminders\",\"1.3.0\"],[\"apps\",\"privacy\",\"2.0.0\"],[\"apps\",\"provisioning_api\",\"1.20.0\"],[\"apps\",\"recommendations\",\"3.0.0\"],[\"apps\",\"related_resources\",\"1.5.0\"],[\"apps\",\"serverinfo\",\"2.0.0\"],[\"apps\",\"settings\",\"1.13.0\"],[\"apps\",\"support\",\"2.0.0\"],[\"apps\",\"survey_client\",\"2.0.0\"],[\"apps\",\"text\",\"4.1.0\"],[\"apps\",\"twofactor_backupcodes\",\"1.19.0\"],[\"apps\",\"user_status\",\"1.10.0\"],[\"apps\",\"viewer\",\"3.0.0\"],[\"apps\",\"weather_status\",\"disabled\"],[\"apps\",\"federation\",\"disabled\"],[\"apps\",\"photos\",\"3.0.2\"],[\"apps\",\"files_sharing\",\"1.22.0\"],[\"apps\",\"contactsinteraction\",\"1.11.0\"],[\"apps\",\"updatenotification\",\"disabled\"],[\"apps\",\"webhook_listeners\",\"1.1.0-dev\"],[\"apps\",\"bruteforcesettings\",\"3.0.0\"],[\"apps\",\"admin_audit\",\"1.20.0\"],[\"apps\",\"deck\",\"disabled\"],[\"apps\",\"twofactor_totp\",\"12.0.0-dev\"],[\"apps\",\"tasks\",\"disabled\"],[\"apps\",\"contacts\",\"disabled\"],[\"apps\",\"notes\",\"disabled\"],[\"apps\",\"fulltextsearch_elasticsearch\",\"disabled\"],[\"apps\",\"fulltextsearch\",\"disabled\"],[\"apps\",\"files_fulltextsearch\",\"disabled\"],[\"apps\",\"whiteboard\",\"disabled\"],[\"apps\",\"notify_push\",\"1.0.0\"],[\"apps\",\"spreed\",\"disabled\"],[\"apps\",\"richdocuments\",\"disabled\"],[\"apps\",\"calendar\",\"5.0.9\"],[\"apps\",\"app_api\",\"4.0.3\"],[\"apps\",\"nextcloud-aio\",\"0.7.0\"],[\"apps\",\"sociallogin\",\"5.7.0\"],[\"apps\",\"suspicious_login\",\"8.0.0\"],[\"apps\",\"twofactor_nextcloud_notification\",\"4.0.0\"],[\"apps\",\"groupfolders\",\"18.0.8\"],[\"apps\",\"group_everyone\",\"0.1.16\"],[\"apps\",\"geoblocker\",\"0.5.15\"],[\"stats\",\"num_files\",3514],[\"stats\",\"num_users\",4],[\"stats\",\"num_storages\",5],[\"stats\",\"num_storages_local\",1],[\"stats\",\"num_storages_home\",4],[\"stats\",\"num_storages_other\",0],[\"stats\",\"num_comments\",7],[\"stats\",\"num_comment_markers\",0],[\"stats\",\"num_systemtags\",0],[\"stats\",\"num_systemtags_mappings\",0],[\"files_sharing\",\"num_shares\",11],[\"files_sharing\",\"num_shares_user\",1],[\"files_sharing\",\"num_shares_groups\",2],[\"files_sharing\",\"num_shares_link\",0],[\"files_sharing\",\"num_shares_link_no_password\",0],[\"files_sharing\",\"num_fed_shares_sent\",0],[\"files_sharing\",\"num_fed_shares_received\",0],[\"files_sharing\",\"permissions_2_5\",8],[\"files_sharing\",\"permissions_0_31\",1],[\"files_sharing\",\"permissions_1_5\",2],[\"encryption\",\"enabled\",\"no\"],[\"encryption\",\"default_module\",\"no\"]]}"
"suspicious_login": {
"installed_version": "8.0.0",
"enabled": "yes"
"systemtags": {
"types": "logging",
"enabled": "yes",
"tasks": {
"installed_version": "0.16.1",
"types": "",
"enabled": "no"
"text": {
"types": "dav",
"enabled": "yes",
"installed_version": "4.1.0"
"theming": {
"types": "logging",
"enabled": "yes",
"installed_version": "2.5.0",
"slogan": "***REMOVED SENSITIVE VALUE***",
"name": "Bunker496 Cloud",
"logoMime": "image\/png",
"url": "***REMOVED SENSITIVE VALUE***",
"cachebuster": "12",
"background_color": "#c4c4c4",
"primary_color": "#5b64b3",
"backgroundMime": "image\/jpeg",
"logoDimensions": "406x314"
"twofactor_backupcodes": {
"types": "",
"enabled": "yes",
"installed_version": "1.19.0"
"twofactor_nextcloud_notification": {
"installed_version": "4.0.0",
"types": "",
"enabled": "yes"
"twofactor_totp": {
"installed_version": "12.0.0-dev",
"types": "",
"enabled": "yes"
"updatenotification": {
"types": "",
"enabled": "no"
"user_status": {
"types": "",
"enabled": "yes",
"installed_version": "1.10.0"
"viewer": {
"types": "",
"enabled": "yes",
"weather_status": {
"types": "",
"installed_version": "1.10.0",
"enabled": "no"
"webhook_listeners": {
"installed_version": "1.1.0-dev",
"enabled": "yes"
"whiteboard": {
"installed_version": "1.0.5",
"types": "",
"jwt_secret_key": "***REMOVED SENSITIVE VALUE***",
"enabled": "no",
"collabBackendUrl": "https:\/\/cloud.bunker496.de\/whiteboard"
"workflowengine": {
"enabled": "yes",
"installed_version": "2.12.0"
The output of occ app:list
(if possible).
- activity: 3.0.0
- admin_audit: 1.20.0
- app_api: 4.0.3
- bruteforcesettings: 3.0.0
- calendar: 5.2.0
- circles: 30.0.0
- comments: 1.20.1
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- firstrunwizard: 3.0.0
- geoblocker: 0.5.16
- group_everyone: 0.1.17
- groupfolders: 18.1.2
- logreader: 3.0.0
- notifications: 3.0.0
- oauth2: 1.18.1
- password_policy: 2.0.0
- photos: 3.0.2
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- sociallogin: 5.9.2
- support: 2.0.0
- survey_client: 2.0.0
- suspicious_login: 8.0.0
- systemtags: 1.20.0
- text: 4.1.0
- theming: 2.5.0
- twofactor_totp: 12.0.0-dev
- user_status: 1.10.0
- viewer: 3.0.0
- workflowengine: 2.12.0
- contacts: 7.0.4 (installed 7.0.4)
- deck: 1.14.4 (installed 1.14.4)
- encryption: 2.18.0
- federation: 1.20.0 (installed 1.20.0)
- files_external: 1.22.0
- files_fulltextsearch: 31.0.0 (installed 31.0.0)
- fulltextsearch: 30.0.1 (installed 30.0.1)
- fulltextsearch_elasticsearch: 30.0.1 (installed 30.0.1)
- notes: 4.11.0 (installed 4.11.0)
- richdocuments: 8.5.6 (installed 8.5.6)
- spreed: 20.1.5 (installed 20.1.5)
- tasks: 0.16.1 (installed 0.16.1)
- user_ldap: 1.21.0
- weather_status: 1.10.0 (installed 1.10.0)
- whiteboard: 1.0.5 (installed 1.0.5)
