Post actions after disabling encryption
NC 11.0.3
Ubuntu 16.04
I had encryption enabled but due to many issues and the fact that I don’t use external storage I decided to disable it offline using occ; this all went fine.
I would only suggest to the doc page: https://docs.nextcloud.com/server/11/admin_manual/configuration_files/encryption_configuration.html
to have added that on the end you still need to manually de-activate then the encryption app.
If you don’t do this you still will be asked to update his encryption key after a user did himself a password reset.
Hello, how can I do that?
