example
longer
example
here
Nextcloud version (eg, 18.0.2):
Operating system and version (eg, Ubuntu 20.04):
PHP version (eg, 7.1):
PASTE HERE
PASTE HERE
PASTE HERE
Having real problems forwarding port 443 on my router. I have done port forwarding before and managed it OK.
I have a new router. Maybe the router is using port 443?
Port 80 is fine.
