Polls: running polls are moved into archive, manual restoring helps only temporary
Dear Forum,
since some days my cloud is now facing the following issue: Polls is not running properly. Each morning Polls are moved into archive. Manual restoring helps only for one day.This strange behaviour happend without any changes.
Details:
Nextcloud version: 22.2.3
Operating system and version : 20.04
nginx version: 1.21.4
PHP version : 7.4.3
Polls version: 3.3.0
I checked and applied: The system is completely updated (Linux/Nextcloud) now and a MariaDB error (“Cannot use object of type stdClass as array”) is resolved. No Change.
Is this the first time you’ve seen this error?: Yes
Steps to replicate it: no idea, it happened with out any changes.
nothing
Does anyone have any idea? Glad for each tipp!!!
Best Joon
I’m personally not using the pools app, but from what I understood you can configure how long a poll should be valid and there also seems to be an option to automatically archive outdated polls, based on the change notes:
Hi j-ed,
thanks for your quick answer. But unfortunately the tip didn’t solve the problem.
Update 3.2.0 worked fine. 3.3.0 doesn’t work correct. Every morning I have to restore all polls manually. That’s really annoying.
Is it possible that 3.3.0 is still a nighty version and “instabile” for 22.2. ?
This might cause the issue, since it started out of the blue. In Oct. all polls worked. Only those which I started in Nov. archive themselves.
Where Do I get a working version for my system? And: is it possible to restore the issue backendwise without loosing all public links?
Best Joon
There seems to be a bug with auto archiving. Disabling it works as a workaround.
Yes. There is a bug in the selection. Will be fixed in the next version. Until then, please disable the auto archive. Sorry for that.
Hi dartcafe, how and where is it possible to disable auto archive? And when does the next update come?
Hi All,
in case somebody else has this issue too: The bug will be fixed 3.4.0.
Best Joon
