example
longer
example
here
Nextcloud version (eg, 20.0.5): 20.0.6
Operating system and version (eg, Ubuntu 20.04): centos7
Apache or nginx version (eg, Apache 2.4.25): Install nextcloud by Docker
PHP version (eg, 7.4): Install nextcloud by Docker
The issue you are facing: Uploading files to the Group folders
Is this the first time you’ve seen this error? (Y/N): Just getting started
- After start the plugin Group folders,I create a Group folder。
- When I upload a picture to the group folder, this prompt pops up:path needs to be relative to the system wide data folder and point to a user specific file。The uploaded picture cannot be seen。
- When I re-upload the picture agian,pops up conflict selection
- Select the New File or the existing file,even choose “Cancel”,The picture appears。
Error PHP Error: Cannot modify header information - headers already sent by (output started at /var/www/html/3rdparty/sabre/http/lib/Sapi.php:132) at /var/www/html/apps/dav/lib/Connector/Sabre/File.php#691
<<closure>>
OC\Log\ErrorHandler::onError(2, "Cannot modi ... )", "/var/www/ht ... p", 691, { string: "X ... "})
/var/www/html/apps/dav/lib/Connector/Sabre/File.php - line 691:
header("X-Hash-MD5: ... 8")
/var/www/html/apps/dav/lib/Connector/Sabre/File.php - line 189:
OCA\DAV\Connector\Sabre\File->header("X-Hash-MD5: ... 8")
<<closure>>
OCA\DAV\Connector\Sabre\File->OCA\DAV\Connector\Sabre\{closure}("*** sensiti ... *")
/var/www/html/lib/private/Files/Stream/HashWrapper.php - line 71:
call_user_func(Closure {}, "*** sensiti ... *")
<<closure>>
OC\Files\Stream\HashWrapper->stream_close()
/var/www/html/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php - line 132:
fclose(null)
/var/www/html/lib/private/Files/Stream/HashWrapper.php - line 75:
Icewind\Streams\Wrapper->stream_close()
<<closure>>
fclose(null)
/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 319:
/var/www/html/apps/dav/appinfo/v1/webdav.php - line 84:
Sabre\DAV\Server->exec()
/var/www/html/remote.php - line 167:
require_once("/var/www/ht ... p")
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'ocde2zfqy9m1',
'passwordsalt' => ' ',
'secret' => ' ',
0 => 'x.x.x.x:8080',
'version' => '20.0.6.1',
'overwrite.cli.url' => 'http://x.x.x.x:8080',
'dbname' => 'nextcloud',
'dbhost' => 'xx.xx.xx.xx:xxxx',
'dbuser' => 'oc_admin',
'dbpassword' => ' ',
'ldapIgnoreNamingRules' => false,
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtpname' => 'admin@it.com',
'mail_smtppassword' => '123456',
'allow_local_remote_servers' => true,
'twofactor_enforced' => 'false',
PASTE HERE
