Nextcloud version latest docker (v30)
Operating system and version (eg, Ubuntu 24.04): Unraid
Apache or nginx version (eg, Apache 2.4.25): whatever is in the docker
PHP version (eg, 8.3): whatever is in the docker
After accessing the nextcloud landing page i see an " Internal Server Error" with no possibility to continue
Is this the first time you’ve seen this error? (Y/N): Yes
- Just access the landing page of my nextcloud
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":3,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"index","method":"GET","url":"/","message":"Class \"OCA\\Dashboard\\Controller\\LayoutApiController\" does not exist","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"ReflectionException","Message":"Class \"OCA\\Dashboard\\Controller\\LayoutApiController\" does not exist","Code":-1,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":450,"function":"__construct","class":"ReflectionClass","type":"->","args":["OCA\\Dashboard\\Controller\\LayoutApiController"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":410,"function":"getAttributeRoutes","class":"OC\\Route\\Router","type":"->","args":["dashboard"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":120,"function":"loadAttributeRoutes","class":"OC\\Route\\Router","type":"->","args":["dashboard"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":260,"function":"loadRoutes","class":"OC\\Route\\Router","type":"->","args":[]},{"file":"/var/www/html/lib/private/Route/Router.php","line":294,"function":"findMatchingRoute","class":"OC\\Route\\Router","type":"->","args":[""]},{"file":"/var/www/html/lib/base.php","line":1001,"function":"match","class":"OC\\Route\\Router","type":"->","args":[""]},{"file":"/var/www/html/index.php","line":24,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Route/Router.php","Line":450,"message":"Class \"OCA\\Dashboard\\Controller\\LayoutApiController\" does not exist","exception":{},"CustomMessage":"Class \"OCA\\Dashboard\\Controller\\LayoutApiController\" does not exist"}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"theming.icon.getfavicon\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.icon.getfavicon\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["theming.icon.getfavicon",["core"],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["theming.icon.getfavicon",["core"],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["theming.Icon.getFavicon",["core"]]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":384,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["theming.Icon.getFavicon",["core"]]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":199,"function":"replaceImagePath","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":["core","favicon.ico"]},{"file":"/var/www/html/lib/private/legacy/template/functions.php","line":222,"function":"imagePath","class":"OC\\URLGenerator","type":"->","args":["core","favicon.ico"]},{"file":"/var/www/html/core/templates/layout.guest.php","line":30,"function":"image_path","args":["core","favicon.ico"]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.icon.getfavicon\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.icon.getfavicon\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"theming.icon.gettouchicon\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.icon.gettouchicon\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["theming.icon.gettouchicon",["core"],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["theming.icon.gettouchicon",["core"],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["theming.Icon.getTouchIcon",["core"]]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":387,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["theming.Icon.getTouchIcon",["core"]]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":199,"function":"replaceImagePath","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":["core","favicon-touch.png"]},{"file":"/var/www/html/lib/private/legacy/template/functions.php","line":222,"function":"imagePath","class":"OC\\URLGenerator","type":"->","args":["core","favicon-touch.png"]},{"file":"/var/www/html/core/templates/layout.guest.php","line":31,"function":"image_path","args":["core","favicon-touch.png"]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.icon.gettouchicon\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.icon.gettouchicon\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"theming.theming.getmanifest\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"theming.theming.getmanifest\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["theming.theming.getmanifest",["core"],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["theming.theming.getmanifest",["core"],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["theming.Theming.getManifest",["core"]]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":397,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["theming.Theming.getManifest",["core"]]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":199,"function":"replaceImagePath","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":["core","manifest.json"]},{"file":"/var/www/html/lib/private/legacy/template/functions.php","line":222,"function":"imagePath","class":"OC\\URLGenerator","type":"->","args":["core","manifest.json"]},{"file":"/var/www/html/core/templates/layout.guest.php","line":33,"function":"image_path","args":["core","manifest.json"]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"theming.theming.getmanifest\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"theming.theming.getmanifest\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"settings.help.help\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"settings.help.help\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["settings.help.help",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["settings.help.help",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["settings.Help.help",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":210,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["settings.Help.help"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":108,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":142,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":242,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":59,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"settings.help.help\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"settings.help.help\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["activity.activities.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["activity.activities.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["activity.Activities.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":347,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["activity.Activities.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":108,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":142,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":242,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":59,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["calendar.view.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["calendar.view.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["calendar.view.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":347,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["calendar.view.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":108,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":142,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":242,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":59,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["dashboard.dashboard.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["dashboard.dashboard.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["dashboard.dashboard.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":347,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["dashboard.dashboard.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":108,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":142,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":242,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":59,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["files.view.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["files.view.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["files.view.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":347,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["files.view.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":108,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":142,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":242,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":59,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist."}}
{"reqId":"uKhUhKBrR1lwrUdEctm3","level":1,"time":"2024-09-23T14:43:30+00:00","remoteAddr":"147.161.139.90","user":"--","app":"no app in context","method":"GET","url":"/","message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36 Edg/129.0.0.0","version":"30.0.0.14","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":374,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["photos.page.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":50,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["photos.page.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":71,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["photos.page.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":347,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["photos.page.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":108,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":142,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":242,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":59,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":161,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":131,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":116,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":147,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":113,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":296,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":89,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["ReflectionException"],500]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":144,"message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist."}}
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'nextcloud.gehrig.info',
1 => '192.168.0.7:81',
'trusted_proxies' =>
0 => '192.168.0.8',
1 => '192.168.0.7',
2 => '172.17.0.7',
'dbtype' => 'sqlite3',
'version' => '30.0.0.14',
'ServerName' => 'nextcloud.gehrig.info',
'overwritehost' => 'nextcloud.gehrig.info',
'overwrite.cli.url' => 'https://nextcloud.gehrig.info',
'mail_from_address' => 'xxx',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'xxx',
'mail_smtphost' => 'xxx',
'mail_smtpport' => '587',
'loglevel' => 0,
'mail_smtpauth' => 1,
'mail_smtpname' => 'xxx',
'mail_smtppassword' => 'xxx',
'theme' => '',
skipped
skipped
I´ve found this bug report: fix(Router): Stop loading routes of disabled apps by provokateurin · Pull Request #44797 · nextcloud/server (github.com)
But i´m confused if this bug would made it into the docker… isnt?
The WebDav is still working - so it´s not completely down… but i dont know how to fix it. Can someone provide me a hint?
Best
Thorsten
