Hi there,
I recently installed NC with snap install on Ubuntu.
sudo snap install nextcloud
installed version 17, but I see there is v18 now.
Is it possible to upgrade my snap installation to version 18?
I have followed this guide to upgrade:
https://docs.nextcloud.com/server/17/admin_manual/maintenance/package_upgrade.html
Running sudo snap refresh nextcloud
gives me:
snap "nextcloud" has no updates available
Also, the Admin > Overview page shows no signs of an update available.
Any tips? Thanks, Danny.
I would also really like to know how and if that is possible… Did you find a solution thus far?
this might be what u are looking for https://github.com/nextcloud/nextcloud-snap/wiki/Release-strategy
or this sudo snap refresh nextcloud --channel=latest/stable
you can see a list of channels by writing snap info nextcloud
Switching from 17 to 18 breaks my nextcloud instance.
sudo snap refresh nextcloud --channel=18/stable works, but the website is not accessible. it results into blank page
Anybody know how to fix this?
revert nextcloud version now, but i would like to upgrade.
