Hi NC experts,
iβd like to move off of a NC hosted on a VM to a NC instance on docker & been struggling to bring container up
I have a Ubuntu VM that is hosting already 10+ different containers and iβd like deploy NC on the same host, but i would like to use dedicated static IP, not just a port the IP for my NC would be 192.168.11.6 All other traffic (between NC and DB, would be internal to the host)
i used this to create my docker-compose.yml: https://github.com/nextcloud/docker/blob/master/.examples/docker-compose/insecure/mariadb/apache/docker-compose.yml
this is my docker-compose.yml:
version: '3'
services:
db:
image: mariadb:10.5
restart: always
volumes:
- ./db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=password
env_file:
- db.env
networks:
- internal
redis:
image: redis:alpine
restart: always
app:
image: nextcloud:apache
restart: always
networks:
vlan11_ext_net:
ipv4_address: 192.168.11.6
internal:
volumes:
- ./nextcloud:/var/www/html
environment:
- MYSQL_HOST=db
- REDIS_HOST=redis
env_file:
- db.env
depends_on:
- db
- redis
cron:
restart: always
volumes:
entrypoint: /cron.sh
depends_on:
- db
- redis
volumes:
db:
nextcloud:
networks:
vlan11_ext_net:
external: true
internal:
driver: bridge
i do have NGINX PRoxy Manager in front of NC, hosted on separate dmz vlan.
Do you see any issue with my config file?
the error i am getting is when i hit my IP is:
Warning: Redis::connect(): php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution in /var/www/html/lib/private/RedisFactory.php on line 124
Warning: Cannot modify header information - headers already sent by (output started at /var/www/html/lib/private/RedisFactory.php:124) in /var/www/html/lib/private/legacy/OC_Template.php on line 349
Internal Server Error The server encountered an internal error and was unable to complete your request. Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report. More details can be found in the server log.
ideally this is what i am trying to accomplish is:
ββββββββββββββββββββββββ
β β
β NPM in DMZ β
βββββββββββββ¬βββββββββββ
β
β
β
β
β
β 192.168.11.5
ββββββββββββββββββββββββββββββΌββββββββββββββββββββββββββββββββ
β docker host β
β β
β βββββββ¬ββββββββββββββββββββββββββββββββββββ¬ββββββββ β
β β β nextcloud app 192.168.11.6 - ext β β β
β β ββββββββββββββββββ¬βββββββββββββββββββ β β
β β β β β
β β βββββββββββββΌββββββββββββββ βΌ β β
β β βmariadb - internal net β β β
β β βredis - internal β β β
β β β β β β
β β βββββββββββββββββββββββββββ β β
β β β β
β β NEXT CLOUD INSTANCE β β
β βββββββββββββββββββββββββββββββββββββββββββββββββββ β
β β
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
β
β
β
Hope this makes sense?
Can you please tell me why i am getting php/redis error or if my docker-compose could be improved
Thank you!
