Hi, I would like to generate the session cookie that I usually get from the login page using the shell. I tried the following
curl --cookie test.txt --cookie-jar test.txt \
-d "user=***name***" \
-d "password=***password***" \
<my nextcloud server>/index.php/login
which gives me a cookie along the lines
# Netscape HTTP Cookie File
# https://curl.haxx.se/docs/http-cookies.html
# This file was generated by libcurl! Edit at your own risk.
#HttpOnly_<my nextcloud server> FALSE /nextcloud TRUE nc_sameSiteCookiestrict true
#HttpOnly_<my nextcloud server> FALSE /nextcloud TRUE nc_sameSiteCookielax true
#HttpOnly_<my nextcloud server> FALSE /nextcloud TRUE oc_sessionPassphrase .....
#HttpOnly_<my nextcloud server> FALSE /nextcloud TRUE ..... ...................
However, when I pass this cookie to my browser and open nextcloud I am not already locked in… what did I miss?
EDIT: moved this to development, as it is not an issue…? Hope to get some help here
