https://mlaviation.org/
We are updating and I can’t click the start update. it is stuck.
I’m using chrome, but if i goto the site in edge i get a new error
Access through untrusted domain
Please contact your administrator. If you are an administrator, edit the “trusted_domains” setting in config/config.php like the example in config.sample.php.
In my config I have the trusted domain
‘trusted_domains’ =>
0 => ‘mlaviation.org’,
Any ideas whats going on?
Nextcloud version (eg, 12.0.2): 14.0.0.3
Operating system and version (eg, Ubuntu 17.04): IDK
Apache or nginx version (eg, Apache 2.4.25): Lightspeed
PHP version (eg, 7.1): 7.2
So it suddenly worked and update… now i get
Security & setup warnings
It’s important for the security and performance of your instance that everything is configured correctly. To help you with that we are doing some automatic checks. Please see the linked documentation for more information.
There are some errors regarding your setup.
Your web server is not yet properly set up to allow file synchronization, because the WebDAV interface seems to be broken.
Error occurred while checking server setup
Your web server is not properly set up to resolve “/.well-known/caldav”. Further information can be found in the documentation.
Your web server is not properly set up to resolve “/.well-known/carddav”. Further information can be found in the documentation.
Please double check the installation guides , and check for any errors or warnings in the log.
Check the security of your Nextcloud over our security scan .
and random http 500 errors that go away on refrsshing and Access through untrusted domain on edge
