i wanted to use PMC under NC18.0.3.
The installation via NC-gui worked without errors.
I have the NC in a docker-container on a OpenMediaVault with a letsencrypt reverse proxy nginx docker. It worked well - the NC-System itself.
How do I use the PCMS right?
The given link to my site give me a NC-ServerError-Page.
I did added the given options to nginx on the nextcloud-docker, i believe it should be there and not in the letsencrypt-docker.
If it would work in the future, how does PCMS works? Is there a good docu / tut out there? It should be dead easy/simple, but I am very near to remove it.
Regards
PS: all I wanted was a Wiki-Like system as NC-App.
You should probably provide us with vital information like the error message you’re seeing and the contents of your log Regarding “how to use it”: All of it is explained in both Pico CMS for Nextcloud settings pages in the admin and personal settings sections respectively.
i’m also getting the same Internal server error ... gibberish…
Do i have to set any additional configurations for getting a PicoCMS site running in Nextcloud?
Is there any “Getting Started” documentation for PicoCMS on Nextcloud?
