Hello there,
I am currently facing the Problem, that my .php Files get downloaded, rather then executed.
As said above I am currently using a CentOS 7 Server with nginx.
I have subdirectories for my vhosts (var/www/vhosts/nexctloud)
I am using the official nginx config for subdirectories found here: https://docs.nextcloud.com/server/15/admin_manual/installation/nginx.html
I didn’t touch it other than changing the hostname to to domain I want and changing to paths to my nextcloud installation.
The upstream php-handler is set to 127.0.0.1:9000 which is also set in my php-fpm/www.conf (although I would prefer using the unix socket, but I didn’t find out how it is named for php7.2)
All services are up and running, and after countless hours of following online tutorials and trying out dozens of different setups I still got nothing that works for me.
I’m pretty new to linux server administration though, and I know practically nothing of php. So maybe the solution is pretty simple I don’t know.
Maybe you guys can help me out here?
