after last mastercontainer update, this message went away.
After less than a week it’s back. And so far, I havent’ been able to find how to change opcache.memory_consumption. I could change it on a standard server, but I can’t manage in docker and AiO.
I’re read several threads about it, but havent found how to access to the right php.ini file.
Thanks if you can share your experience on that topic
There are some warnings regarding your setup.
- The PHP OPcache module is not properly configured. See the documentation
for more information.
- The OPcache buffer is nearly full. To assure that all scripts can be hold in cache, it is recommended to apply
to your PHP configuration with a value higher than128
