Dear All,
I have php error at logging, How I can fix it.
Nextcloud version (eg, 20.0.5): 20.0.5
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.1 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.4): PHP 7.4.3
Is this the first time you’ve seen this error? (Y):
- Error: Array to string conversion at /var/www/html/lib/private/L10N/L10NString.php#79
<<closure>>
OC\Log\ErrorHandler::onError()
/var/www/html/lib/private/L10N/L10NString.php - line 79:
vsprintf()
/var/www/html/lib/private/L10N/L10N.php - line 110:
OC\L10N\L10NString->__toString()
/var/www/html/lib/private/L10N/LazyL10N.php - line 53:
OC\L10N\L10N->t()
/var/www/html/apps/updatenotification/lib/Notification/Notifier.php - line 145:
OC\L10N\LazyL10N->t()
/var/www/html/lib/private/Notification/Manager.php - line 299:
OCA\UpdateNotification\Notification\Notifier->prepare()
/var/www/html/apps/notifications/lib/Controller/EndpointController.php - line 106:
OC\Notification\Manager->prepare()
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 169:
OCA\Notifications\Controller\EndpointController->listNotifications()
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 100:
/var/www/html/lib/private/AppFramework/App.php - line 152:
/var/www/html/lib/private/Route/Router.php - line 309:
OC\AppFramework\App::main()
/var/www/html/ocs/v1.php - line 88:
OC\Route\Router->match()
/var/www/html/ocs/v2.php - line 24:
require_once("/var/www/html/ocs/v1.php")
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '',
1 => '',
2 => '',
'version' => '20.0.5.2',
'overwrite.cli.url' => '',
'dbname' => '',
'dbhost' => 'localhost',
[Wed Aug 04 14:28:20.295748 2021] [access_compat:error] [pid 12079] [client 183.88.110.189:54187] AH01797: client denied by server configuration: /var/www/html/data/.ocdata
[Wed Aug 04 14:31:25.746045 2021] [access_compat:error] [pid 12502] [client 183.88.110.189:54958] AH01797: client denied by server configuration: /var/www/html/data/.ocdata
