Environment
- Nextcloud Version: App Version: 32.0.6
Issue
The Photos page loads as a blank page when the user locale is set to:
English
However, if I change the locale to:
English (World)
The Photos app loads normally again.
No visible PHP errors in the UI. Other apps work normally. The issue appears to be related to locale handling.
Root Cause (Suspected)
It seems that using the generic en locale causes a formatting or intl-related issue that affects the Photos app rendering. Explicitly defining both language and locale in config.php resolves the issue.
Fix
I added the following entries to:
config/config.php
'default_language' => 'en',
'default_locale' => 'en_US',
After saving the file and restarting the container/jail, the Photos page loads correctly even when the user profile language is set to English.
Result
Photos page no longer blank
No UI rendering issues
Stable behavior across sessions
Question
Is this expected behavior when using the generic en locale?
Should Nextcloud automatically normalize en to en_US internally?
Would appreciate confirmation from others or clarification from maintainers.
