Nextcloud version (eg, 20.0.5): 3.4.2
Operating system and version (eg, Ubuntu 20.04): Windows 10 21H2
Apache or nginx version (eg, Apache 2.4.25): N/A
PHP version (eg, 7.4): N/A
When trying to set up folder sync, I receive a permission error when selecting a network drive as the target, even though I have full permissions.
Click ‘Add Folder Sync Connection’
Set the folder to “H:\Nextcloud”
Permission error
I have a ‘debug archive’ from the client as well, but that doesn’t seem to be something I can upload here.
Is drive H: a hard drive or a removable drive?
Do you have write permission to H:\Nextcloud, if you create a file in Explorer there?
Did you try annother Drive and folder f.ex. C:\Users\<username>\Documents\Nextcloud?
Is this the version of your desktop-client? - I recommend to try an older version as test f.ex. version 2.6.5 or 3.3.5 (both work proprely on my computers day by day).
I am not sure, but it might be possible, that Nextcloud client cannot sync to mapped drives, because sync may fail, if the mapped drive is disconnected.
I have had network drives working in the past, it just seems like there was a change at some point that caused this to stop working. The only reason I discovered the issue was that I moved my nextcloud server and had to re-sync everything.
