docker tag mariadb:latest
installs version 10.8 which is not supported by NC as of now. Please try using supported version e.g. 10.5.
Aha, if I use my root volume instead of an external drive, everything works.
I thought EXT4 as OK…?
Thank you; I have updated to 10.5.
There is no problem with EXT4 as the filesystem, but there could be some issue with how it’s mounted. Can you show your mount command?
The following should be the mount options.
type ext4 (rw,nosuid,nodev,relatime,errors=remount-ro,uhelper=udisks2)
Does this look correct, @KarlF12?
I think so. Are you using the acl package in the OS?
If you go into the container with docker exec -it -u www-data nextcloud-app bash
are you able to read/write files in the user’s data folder?
Hi Karl
So I just did docker-compose up
on the above file with an updated volume on the external drive.
Exactly as I did in my original post… and, as far as I can tell, everything works now.
The only difference is the MariaDB version 10.5 as pointed out by @wwe.
… I spoke too soon.
Whilst everything worked perfectly fine before, restarting the machine introduces errors.
Starting the containers again using sudo docker-compose up
and attempting to access the localhost:8080
yields the installation page. Attempting to access localhost:8080/apps/files/
yields the following error in the browser:
Forbidden
You don’t have permission to access this resource.
Apache/2.4.53 (Debian) Server at localhost Port 8080
Which in turn corresponds to the following error:
nextcloud-app | [Sun Jul 03 21:21:19.203653 2022] [autoindex:error] [pid 31] [client 172.20.0.1:43014] AH01276: Cannot serve directory /var/www/html/apps/files/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive
nextcloud-app | 172.20.0.1 - - [03/Jul/2022:21:21:19 +0000] "GET /apps/files/ HTTP/1.1" 403 679 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
The Cannot serve directory /var/www/html/apps/files/: No matching DirectoryIndex (index.php,index.html)
part is particularly interesting, because the directory created on my external volume remains as it was prior to the restart when everything worked. I can see all the files and directories that supposedly are not there.
This one is indicating a web server configuration issue.
Did you try this?
this sound like the database is not in the config anymore (or there is no more config at all).
as Nextcloud doesn’t (no DB) run you are trying to access the folder …/app/filles through your webserver which is not allowed, but this is not an issue here.
