Permission denied: Can’t write or read changes with clients
I don’t have writing access to my data (and I can see no changes) since about 10 days, when I uninstalled something else (homebridge on docker). Nextcloud is installed on an external USB-Drive and has 3 users. The data-path is /media/myCloudDrive/ncdata/ncp/files/.
To check the rights I used
ls -ld /media/myCloudDrive/ncdata/ncp/files/
And got back
drwxrwx--- 1 www-data www-data 106 Jul 31 2021 /media/myCloudDrive/ncdata/ncp/files/
For getent group www-data
I got
www-data:x:33:pi,jenny,muelli,ncp
I already updated to 1.50 and tried the „permission fix“-option in the panel (ip:4443)
What is wrong?
Thank you for helping ideas and sorry if this topic is double- I didnt find a solution for me here…
Please:
  • post the full error message (log entry)
  • confirm the permissions on all the parent folders above /media/myCloudDrive/ncdata/ncp/files
Hi, here the log-Message (hope I got the right, I forced a mistake with creating an empty document)
{“reqId”:“ZuBhqRRKL2-kXNuatoZUzgAAjwU”,“level”:3,“time”:“2024-09-10T15:11:38+00:00”,“remoteAddr”:“77.21.245.228”,“user”:“muelli”,“app”:“no app in context”,“method”:“POST”,“url”:“/ocs/v2.php/apps/files/api/v1/directEditing/create?path=/Cloud-Daten/Bilder/Auto-Upload%20Muelli/2024/Unbenannt.md&editorId=text&creatorId=textdocument&templateId=document”,“message”:{“Exception”:“OCP\Files\ForbiddenException”,“Message”:“Following symlinks is not allowed”,“Code”:0,“Trace”:[{“file”:“/var/www/nextcloud/lib/private/Files/Storage/Local.php”,“line”:161,“function”:“getSourcePath”,“class”:“OC\Files\Storage\Local”,“type”:“->”,“args”:[“Bilder/Auto-Upload Maus”]},{“file”:“/var/www/nextcloud/lib/private/Files/Storage/Common.php”,“line”:884,“function”:“getMetaData”,“class”:“OC\Files\Storage\Local”,“type”:“->”,“args”:[“Bilder/Auto-Upload Maus”]},{“file”:“/var/www/nextcloud/lib/private/Files/Storage/Wrapper/PermissionsMask.php”,“line”:158,“function”:“getDirectoryContent”,“class”:“OC\Files\Storage\Common”,“type”:“->”,“args”:[“Bilder”]},{“function”:“getDirectoryContent”,“class”:“OC\Files\Storage\Wrapper\PermissionsMask”,“type”:“->”,“args”:[“Bilder”]},{“file”:“/var/www/nextcloud/lib/private/Files/Cache/Scanner.php”,“line”:408,“function”:“iterator_to_array”,“args”:[{“class”:“Generator”}]},{“file”:“/var/www/nextcloud/lib/private/Files/Cache/Scanner.php”,“line”:388,“function”:“handleChildren”,“class”:“OC\Files\Cache\Scanner”,“type”:“->”,“args”:[“Bilder”,false,3,232545,true,0]},{“file”:“/var/www/nextcloud/lib/private/Files/Cache/Scanner.php”,“line”:340,“function”:“scanChildren”,“class”:“OC\Files\Cache\Scanner”,“type”:“->”,“args”:[“Bilder”,false,3,232545,true]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1339,“function”:“scan”,“class”:“OC\Files\Cache\Scanner”,“type”:“->”,“args”:[“Bilder”,false]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1383,“function”:“getCacheEntry”,“class”:“OC\Files\View”,“type”:“->”,“args”:[{“cache”:{“class”:“OC\Files\Cache\Cache”},“scanner”:{“class”:“OC\Files\Cache\Scanner”},“watcher”:null,“propagator”:{“class”:“OC\Files\Cache\Propagator”},“updater”:{“class”:“OC\Files\Cache\Updater”},“class”:“OCA\Files_Trashbin\Storage”},“Bilder”,“/muelli/files/Cloud-Daten/Bilder”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/Root.php”,“line”:201,“function”:“getFileInfo”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/muelli/files/Cloud-Daten/Bilder”]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/Node.php”,“line”:287,“function”:“get”,“class”:“OC\Files\Node\Root”,“type”:“->”,“args”:[“/muelli/files/Cloud-Daten/Bilder”]},{“file”:“/var/www/nextcloud/lib/private/Share20/Manager.php”,“line”:1647,“function”:“getParent”,“class”:“OC\Files\Node\Node”,“type”:“->”,“args”:},{“file”:“/var/www/nextcloud/lib/private/Share20/ShareHelper.php”,“line”:53,“function”:“getAccessList”,“class”:“OC\Share20\Manager”,“type”:“->”,“args”:[{“class”:“OC\Files\Node\Folder”},true,true]},{“file”:“/var/www/nextcloud/apps/activity/lib/FilesHooks.php”,“line”:625,“function”:“getPathsForAccessList”,“class”:“OC\Share20\ShareHelper”,“type”:“->”,“args”:[{“class”:“OC\Files\Node\File”}]},{“file”:“/var/www/nextcloud/apps/activity/lib/FilesHooks.php”,“line”:193,“function”:“getUserPathsFromPath”,“class”:“OCA\Activity\FilesHooks”,“type”:“->”,“args”:[“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”,“muelli”]},{“file”:“/var/www/nextcloud/apps/activity/lib/FilesHooks.php”,“line”:143,“function”:“addNotificationsForFileAction”,“class”:“OCA\Activity\FilesHooks”,“type”:“->”,“args”:[“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”,“file_created”,“created_self”,“created_by”]},{“file”:“/var/www/nextcloud/apps/activity/lib/FilesHooksStatic.php”,“line”:47,“function”:“fileCreate”,“class”:“OCA\Activity\FilesHooks”,“type”:“->”,“args”:[“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”]},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_Hook.php”,“line”:110,“function”:“fileCreate”,“class”:“OCA\Activity\FilesHooksStatic”,“type”:“::”,“args”:[{“run”:true,“path”:“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”}]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1274,“function”:“emit”,“class”:“OC_Hook”,“type”:“::”,“args”:[“OC_Filesystem”,“post_create”,{“run”:true,“path”:“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”}]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:1202,“function”:“runHooks”,“class”:“OC\Files\View”,“type”:“->”,“args”:[[“touch”,“create”,“write”],“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”,true]},{“file”:“/var/www/nextcloud/lib/private/Files/View.php”,“line”:571,“function”:“basicOperation”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“touch”,“/muelli/files/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”,[“touch”,“create”,“write”],null]},{“file”:“/var/www/nextcloud/lib/private/Files/Node/Folder.php”,“line”:189,“function”:“touch”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/muelli/files/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”]},{“file”:“/var/www/nextcloud/lib/private/DirectEditing/Manager.php”,“line”:128,“function”:“newFile”,“class”:“OC\Files\Node\Folder”,“type”:“->”,“args”:[“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”]},{“file”:“/var/www/nextcloud/apps/files/lib/Controller/DirectEditingController.php”,“line”:82,“function”:“create”,“class”:“OC\DirectEditing\Manager”,“type”:“->”,“args”:[“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”,“text”,“textdocument”,“document”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php”,“line”:170,“function”:“create”,“class”:“OCA\Files\Controller\DirectEditingController”,“type”:“->”,“args”:[“/Cloud-Daten/Bilder/Auto-Upload Muelli/2024/Unbenannt.md”,“text”,“textdocument”,“document”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php”,“line”:100,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”,“args”:[{“class”:“OCA\Files\Controller\DirectEditingController”},“create”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/App.php”,“line”:137,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:“->”,“args”:[{“class”:“OCA\Files\Controller\DirectEditingController”},“create”]},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php”,“line”:47,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:“::”,“args”:[“OCA\Files\Controller\DirectEditingController”,“create”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{“_route”:“ocs.files.DirectEditing.create”}]},{“function”:“__invoke”,“class”:“OC\AppFramework\Routing\RouteActionHandler”,“type”:“->”,“args”:[{“_route”:“ocs.files.DirectEditing.create”}]},{“file”:“/var/www/nextcloud/lib/private/Route/Router.php”,“line”:297,“function”:“call_user_func”,“args”:[{“class”:“OC\AppFramework\Routing\RouteActionHandler”},{“_route”:“ocs.files.DirectEditing.create”}]},{“file”:“/var/www/nextcloud/ocs/v1.php”,“line”:88,“function”:“match”,“class”:“OC\Route\Router”,“type”:“->”,“args”:[“/ocsapp/apps/files/api/v1/directEditing/create”]},{“file”:“/var/www/nextcloud/ocs/v2.php”,“line”:24,“args”:[“/var/www/nextcloud/ocs/v1.php”],“function”:“require_once”}],“File”:“/var/www/nextcloud/lib/private/Files/Storage/Local.php”,“Line”:463,“CustomMessage”:“–”},“userAgent”:“Mozilla/5.0 (iOS) Nextcloud-iOS/5.5.5 AppleWebKit/605.1.15 Mobile/15E148”,“version”:“19.0.2.2”}
And the permissions:
pi@nextcloudpi:~ $ ls -ld /media
drwxr-xr-x 3 www-data www-data 4096 Sep 7 19:12 /media
pi@nextcloudpi:~ $ ls -ld /media/myCloudDrive
drwxr-xr-x 1 www-data www-data 12 Nov 4 2020 /media/myCloudDrive
pi@nextcloudpi:~ $ ls -ld /media/myCloudDrive/ncdata
drwxrwx— 1 www-data www-data 234 Sep 10 14:00 /media/myCloudDrive/ncdata
pi@nextcloudpi:~ $ ls -ld /media/myCloudDrive/ncdata/ncp
drwxrwx— 1 www-data www-data 90 Jul 12 2021 /media/myCloudDrive/ncdata/ncp
pi@nextcloudpi:~ $ ls -ld /media/myCloudDrive/ncdata/ncp/files
drwxrwx— 1 www-data www-data 106 Jul 31 2021 /media/myCloudDrive/ncdata/ncp/files
I solved it: A syslink stopped the sync. I removed it and scanned with sudo -u www-data php /var/www/nextcloud/occ files:scan --all
