Daphne, thx for supporting people about performance issues.
There are some poeple in my environment, who also complain about.
I did disable circle, but see not a difference.
in another forum i did recommend the following:
for me it was the dashboard.
Dashboard with all active options needs very, very much resources.
Some users reported issues with the loading time of Dashboard (up to 1 minute and more), while others did not.
Since Nextcloud is a resource-hungry application (PHP), it needs strong servers (especially memory/CPU) but also central is the internet speed - at least 100Mbits (up/down) should be available. Anything lower than that will cause perf. problems.
Then it also plays a role how many apps are installed.
About CIRCLE, Daphne … i saw this is a “FEATURED APP” - so one can assume, that this app should be fully supported (under the control of nextcloud GmbH), without any side effects in performance
