Performance issue with Collabora - I see a couple of warnings when initializing
    • 32.0.3
    • Debian 6.1.158-1
    • Apache/2.4.66
    • caddy -vv2.10.2
    • 8.3.28
    • Yes
    • Not sure
    • AIO
If I want to open any kind of document docs, pptx, it takes up to 10s until the file opens.
Even when I completely remove the container and prune it, I get the same issue.
  1. Move to my documents
  2. Open even an empty docx document
This looks like the culprit, but I have no idea how to fix this.
2026-01-07T04:02:56.862818031Z frk-00017-00017 2026-01-07 04:02:56.862690 +0000 [ forkit ] WRN  The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2026-01-07T04:02:56.871982358Z wsd-00007-00030 2026-01-07 04:02:56.870544 +0000 [ remotefontconfig_poll ] ERR  Remote config server has response status code: 502 (Bad Gateway)| wsd/RemoteConfig.cpp:133
2026-01-07T04:02:56.875919370Z frk-00017-00017 2026-01-07 04:02:56.875787 +0000 [ forkit ] WRN  The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2026-01-07T04:02:56.884675006Z frk-00017-00017 2026-01-07 04:02:56.884479 +0000 [ forkit ] WRN  The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2026-01-07T04:03:56.942047181Z wsd-00007-00030 2026-01-07 04:03:56.941299 +0000 [ remotefontconfig_poll ] ERR  Remote config server has response status code: 502 (Bad Gateway)| wsd/RemoteConfig.cpp:133
2026-01-07T18:05:58.221324904Z frk-00017-11830 2026-01-07 18:05:58.220984 +0000 [ subforkit_001 ] WRN  The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
2026-01-07T04:04:08.084288611Z Waiting for nextcloud-aio-apache to become available...
2026-01-07T04:04:08.234072350Z [07-Jan-2026 04:04:08] NOTICE: fpm is running, pid 237
2026-01-07T04:04:08.234119000Z [07-Jan-2026 04:04:08] NOTICE: ready to handle connections
2026-01-07T04:04:23.089876527Z Connection to nextcloud-aio-apache (172.18.0.9) 11000 port [tcp/*] succeeded!
2026-01-07T04:04:23.093458271Z Activating Collabora config...
2026-01-07T04:04:24.667800500Z ✓ Set WOPI url to http://nextcloud-aio-apache:23973
2026-01-07T04:04:24.667840006Z ✓ Set callback url to http://nextcloud-aio-apache:23973
2026-01-07T04:04:24.667843784Z Checking configuration
2026-01-07T04:04:24.667859784Z 🛈 Configured WOPI URL: http://nextcloud-aio-apache:23973
2026-01-07T04:04:24.667862931Z 🛈 Configured public WOPI URL: https://*****
2026-01-07T04:04:24.667866558Z 🛈 Configured callback URL: http://nextcloud-aio-apache:23973
2026-01-07T04:04:24.667870194Z
2026-01-07T04:04:24.775282088Z ✓ Fetched /hosting/discovery endpoint
2026-01-07T04:04:24.778779249Z ✓ Valid mimetype response
2026-01-07T04:04:24.781429342Z ✓ Valid capabilities entry
2026-01-07T04:04:24.827542641Z ✓ Fetched /hosting/capabilities endpoint
2026-01-07T04:04:24.828089447Z ✓ Detected WOPI server: Collabora Online Development Edition 25.04.7.3
2026-01-07T04:04:24.830114071Z
2026-01-07T04:04:24.830127868Z Collabora URL (used for Nextcloud to contact the Collabora server):
2026-01-07T04:04:24.830131575Z   http://nextcloud-aio-apache:23973
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "*******",
        "overwriteprotocol": "https",
            "localhost",
        "dbtype": "pgsql",
        "version": "32.0.3.2",
        "overwrite.cli.url": "https:\/*******\/",
        "dbport": "",
        "updater.release.channel": "beta",
        "loglevel": "2",
        "log_type": "file",
        "log_rotate_size": "10485760",
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita"
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": "30",
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "mail_smtpsecure": "ssl",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": 1,
        "mail_smtpport": "465",
        "twofactor_enforced": "true",
            "admin"
        "dbpersistent": false,
        "appsallowlist": false,
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-musl",
        "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
        "updatechecker": false,
        "data-fingerprint": "a32b829922367631e96aa91298b430d6",
        "app_install_overwrite": [],
        "config_preset": 2,
        "DOMAIN": "*******"
  - activity: 5.0.0-dev.0
  - admin_audit: 1.22.0
  - circles: 32.0.0
  - comments: 1.22.0
  - contactsinteraction: 1.13.1
  - dashboard: 7.12.0
  - dav: 1.34.2
  - encryption: 2.20.0
  - federation: 1.22.0
  - files: 2.4.0
  - files_external: 1.24.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0-dev.0
  - guests: 4.6.0
  - logreader: 5.0.0-dev.0
  - nextcloud-aio: 0.8.0
  - notes: 4.12.4
  - notifications: 5.0.0-dev.0
  - notify_push: 1.2.1
  - oauth2: 1.20.0
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - richdocuments: 9.0.2
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - support: 4.0.0-dev.0
  - survey_client: 4.0.0-dev.0
  - systemtags: 1.22.0
  - text: 6.0.1
  - theming: 2.7.0
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - whiteboard: 1.5.0
  - workflowengine: 2.14.0
  - app_api: 32.0.0 (installed 4.0.5)
  - calendar: 6.1.3 (installed 6.1.3)
  - contacts: 8.2.0-rc.1 (installed 8.2.0-rc.1)
  - deck: 1.16.3 (installed 1.16.3)
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - memories: 7.7.0 (installed 7.7.0)
  - photos: 5.0.0-dev.1 (installed 5.0.0-dev.1)
  - previewgenerator: 5.11.0 (installed 5.11.0)
  - tasks: 0.17.1 (installed 0.17.1)
  - user_ldap: 1.23.0
