Pb with OCC with Nextcloud Hub 26 Spring (34.0.0)
    • 34.0.0
    -Linux 7.0.10+deb13-amd64
    • replace me
    -swag/nginx 1.26.3
    • 8.4.21
    • Yes
    • Upgrade Nextcloud Hub 26 Spring
    -OMV docker compose
    • no,
I get an empty window without prompt when I launch OCC from the Nextcloud menu. So it impossible for me to use occ command to install Collabora On line Built-in Code server for example. Thanks in advance for any help. Sorry, butI failed to find some configuration file as required to help a faster reply.
{"reqId":"fnxn5xAGkO3Y738aUfJm","level":0,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"admin","app":"files_external","method":"GET","url":"/settings/admin/overview","scriptName":"/index.php","message>
{"reqId":"fnxn5xAGkO3Y738aUfJm","level":1,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"admin","app":"no app in context","method":"GET","url":"/settings/admin/overview","scriptName":"/index.php","mess>
{"reqId":"fnxn5xAGkO3Y738aUfJm","level":0,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"admin","app":"user_status-menucss","method":"GET","url":"/settings/admin/overview","scriptName":"/index.php","me>
{"reqId":"WtgzPrw89lAYioOX8YxR","level":0,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"admin","app":"no app in context","method":"GET","url":"/settings/ajax/checksetup","scriptName":"/index.php","mes>
{"reqId":"WtgzPrw89lAYioOX8YxR","level":1,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"admin","app":"no app in context","method":"GET","url":"/settings/ajax/checksetup","scriptName":"/index.php","mes>
{"reqId":"WtgzPrw89lAYioOX8YxR","level":0,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"admin","app":"no app in context","method":"GET","url":"/ls
{"reqId":"ZHVMvNpyzHncHYLcC0A1","level":0,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"--","app":"webdav","method":"PROPFIND","url":"/remote.php/webdav","scriptName":"/remote.php","message":"No 'Auth>
<","mes>{"reqId":"fnxn5xAGkO3Y738aUfJm","level":0,"time":"2026-06-20T22:30:26+00:00","remoteAddr":"192.168.0.100","user":"admin","app":"files_external","method":"GET","url":"/settings/admin/overview","scriptName":"/index.php",>
PASTE
PASTE HERE
I add the nextcloud.subdomain.conf file in the swag/nginx/proxy.confs directory
## Version 2025/07/18
# make sure that your nextcloud container is named nextcloud
# make sure that your dns has a cname set for nextcloud
# assuming this container is called “swag”, edit your nextcloud container’s config
# located at /config/www/nextcloud/config/config.php and add the following lines before the “);”:
# ‘trusted_proxies’ => [gethostbyname(‘swag’)],
# ‘overwrite.cli.url’ => ‘https://nextcloud.example.com/’,
# ‘overwritehost’ => ‘nextcloud.example.com’,
# ‘overwriteprotocol’ => ‘https’,
# Also don’t forget to add your domain name to the trusted domains array. It should look somewhat like this:
# array (
# 0 => ‘192.168.0.1:444’, # This line may look different on your setup, don’t modify it.
# 1 => ‘nextcloud.example.com’,
server {
  • listen 443 ssl;
    # listen 443 quic;
  • listen [::]:443 ssl;
    # listen [::]:443 quic;
  • server_name nextcloud.;
  • include /config/nginx/ssl.conf;
  • client_max_body_size 0;
  • location / {
  •    include /config/nginx/proxy.conf;
  •   include /config/nginx/resolver.conf;
  •    set $upstream_app nextcloud;
  •    set $upstream_port 443;
  •    set $upstream_proto https;
  •    proxy_pass $upstream_proto://$upstream_app:$upstream_port;
  •    # Hide proxy response headers from Nextcloud that conflict with ssl.conf*
  •    # Uncomment the Optional additional headers in SWAG's ssl.conf to pass Nextcloud's security scan**
# proxy_hide_header Referrer-Policy;
# proxy_hide_header X-Content-Type-Options;
# proxy_hide_header X-Frame-Options;
# proxy_hide_header X-XSS-Protection;
# Disable proxy buffering
  •    proxy_buffering off;
config.php file:
 * WARNING
 * This file gets modified by automatic processes and all lines that are not
 * active code (ie. comments) are lost during that process.
 * If you want to document things with comments or use constants add your settings
 * in a '<NAME>.config.php' file which will be included and rendered into this file.
 * Example:
 *   <?php
 *   $CONFIG = [];
 * See also: https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/config_sample_php_parameters.html#multiple-merged-configuration-files
  'datadirectory' => '/data',
  'instanceid' => 'oceww45ozoue',
  'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
  'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
  'trusted_proxies' =>
    0 => '172.18.0.4/16',
    0 => '192.168.0.105:443',
    1 => 'nextcloud.nashp.archivasso.com',
  'overwrite.cli.url' => 'https://nextcloud.nashp.archivasso.com',
  'overwritehost' => 'nextcloud.nashp.archivasso.com',
  'version' => '34.0.0.12',
  'dbname' => 'nextcloudb',
  'dbhost' => 'mariadb',
  'dbuser' => 'oc_admin',
  'dbpassword' => 'xxxxxxxxxxxxxxx',
  'memories.exiftool' => '/config/www/nextcloud/apps/memories/bin-ext/exiftool-amd64-musl',
  'memories.vod.path' => '/config/www/nextcloud/apps/memories/bin-ext/go-vod-amd64',
  'mail_from_address' => 'xxxxxxxxxxx',
  'mail_smtpmode' => 'smtp',
  'mail_domain' => 'wanadoo.fr',
  'mail_smtphost' => 'smtp.orange.fr',
  'mail_smtpport' => '465',
  'mail_smtpauth' => 1,
  'mail_smtpname' => 'xxxxxxxxxxxxxxxxxxxxx',
   'mail_smtppassword' => 'xxxxxxxxxxxx',
  'default_phone_region' => 'FR',
  'forbidden_filename_basenames' =>
    0 => 'con',
    1 => 'prn',
    2 => 'aux',
    3 => 'nul',
    4 => 'com0',
    5 => 'com1',
    6 => 'com2',
    7 => 'com3',
    8 => 'com4',
    9 => 'com5',
    10 => 'com6',
    11 => 'com7',
    12 => 'com8',
    13 => 'com9',
    14 => 'com¹',
    15 => 'com²',
    16 => 'com³',
    17 => 'lpt0',
    18 => 'lpt1',
    19 => 'lpt2',
    20 => 'lpt3',
    21 => 'lpt4',
    22 => 'lpt5',
    23 => 'lpt6',
    24 => 'lpt7',
    25 => 'lpt8',
    26 => 'lpt9',
    27 => 'lpt¹',
    28 => 'lpt²',
    29 => 'lpt³',
  'forbidden_filename_characters' =>
    0 => '<',
    1 => '>',
    2 => ':',
    3 => '"',
    4 => '|',
    5 => '?',
    6 => '*',
    7 => '\\',
    8 => '/',
  'forbidden_filename_extensions' =>
    0 => ' ',
    1 => '.',
    2 => '.filepart',
    3 => '.part',
  'loglevel' => 0,
  'app_install_overwrite' =>
    1 => 'maps',
    2 => 'occweb',
  'redis' =>
    'host' => 'redis',
    'port' => 6379,
    'timeout' => 0,
    'dbindex' => 0,
  1. enable Nextcloud Office: occ app:enable richdocuments
  2. enable Collabora CODE built-in: occ app:enable richdocumentscode
I fear the issue is that you’re using occweb? Is there shell access available to you?
Hi Syskeeper. Thans for your reply.
Yes I am trying to use OCCweb. Before upgrading to Nextcloud HUB , it worked fine. As I 'm a beginner I am not sure to reply correctly to your second question. For OMV, from which I installed Nextcloud, I use Putty. But for Nextcloud, I don’t know how to put a OCC command.
Hi scubamuc. Thanks for your reply.
I don’t know how to put an OCC command without OCCweb within Nextcloud. Please, is there a way to di it?
its all there in the docs → you need shell access as @SysKeeper mentioned!
so you have shell access to the server :check_mark:
don’t do that as that app is deprecated! see OCC Web - Apps - App Store - Nextcloud , last compatible version was v31 and you’re using v34. better remove that app from your instance.
don’t worry we all started sometime, somewhere, don’t be shy :waving_hand:
this thread explains the steps required:
https://forum.openmediavault.org/index.php?thread/44782-using-the-occ-in-nextcloud/
  • open your putty
  • connect to server via ssh
  • enter the container with docker exec -it nextcloud bash
  • enter the above mentioned occ commands consecutively
      1. enable Collabora CODE built-in: occ app:enable richdocumentscode
bar having used OMV, you’ll need to wait for some folks who know OMV. be patient…
Thanks a lot scubamu!
