hey,
I am very sorry, but I don´t know which client we are using. Maybe anyone can help either:
My college uses a Mac, I have a windows PC. Sometimes he creates a new folder and it syncs, so online in the Browser I can see it. But my PC doesn-t synch. Logfile is empty and there is nothing “not synchonised” Everything seems fine…except that I can´t see the folder on my PC.
This seems to happen, if there are other folders INSIDE the folder. If there are only files in there, I can see it. So maybe the pathdepth is limited? Or ist there any possibility to fix it? The path depth is: C:\Users\myname\Nextcloud\folder\folder\folder\folder/and then the folder, which isn´t shown/then the other folders
Again: If the last folder only has files in it, there is no problem…
I hope, anyone can help. THX a lot in advance!
Best regards
Claudia
So we changed the name and it works out fine…It was no problem for his Mac, but windows didn´t like it.
