I’ve installed nextcloud on my server and every time I want to login I get a password error. I’ve installed it several times and I AM SURE the user and the password are right. What can I do?
Thanks in advance.
Thanks in advance.
please, be more specific about server version, php and db infos…
I have this info:
CenOs Linux 7.5.1084
PHP 7.0.31
MySQL
NextCloud 13.,0.5
The url is www.sempicloud.com/nextcloud
Do you need more info?
Thanks.
unfortunatly yes, mysql version please
Try this:
and “Password forgotten”.
Email settings need to set that you get an email with a new password.
if he is using a mysql >= 8.2, the auth method change and need some conf modification
heck
Sorry, my sql version is 5.5.60
Thanks
I’ve tried this option, but I get an error sending the email.
Thanks
Solved. It was php permissions problem.
Thanks.
Could you explain which php permission error? Just for other user who may ask for it
It was not me. They talked about “server directory permissions”. I’ll try to get more info.
