I crawled through the admin-, user-, and developer documentation searching for forgotten entries referencing to owncloud instead of nextcloud.
You guys have done a fantastic job updating the heapload of documentation available, but it will not come as a surprise, that there are still some inconsistencies here and there.
For what it’s worth, please feel free to use (and modify) this post as a “to-do” tracker for old name rudiments still present
John
“oc_” prefixes or /OC/ directories used on
https://docs.nextcloud.org/server/9/admin_manual/installation/installation_wizard.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_user/user_auth_ftp_smb_imap.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_user/user_auth_ldap_cleanup.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_files/external_storage/dropbox.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_files/encryption_configuration.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_files/files_locking_transactional.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_database/db_conversion.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_database/linux_database_configuration.html (using term “owncloud” as well)
https://docs.nextcloud.org/server/9/developer_manual/general/security.html
https://docs.nextcloud.org/server/9/developer_manual/app/hooks.html
“ocpath” variable used on
https://docs.nextcloud.org/server/9/admin_manual/maintenance/update.html
“owncloud” used several times on
https://docs.nextcloud.org/server/9/admin_manual/configuration_server/config_sample_php_parameters.html
https://docs.nextcloud.org/server/9/admin_manual/issues/code_signing.html (apps.owncloud)
https://docs.nextcloud.org/server/9/developer_manual/app/startapp.html
https://docs.nextcloud.org/server/9/developer_manual/app/info.html (version tags, paths)
https://docs.nextcloud.org/server/9/developer_manual/app/l10n.html
https://docs.nextcloud.org/server/9/developer_manual/android_library/examples.html
https://docs.nextcloud.org/server/9/developer_manual/core/theming.html (also: path)
https://docs.nextcloud.org/server/9/developer_manual/core/configfile.html
referencing /owncloud.log
https://docs.nextcloud.org/server/9/admin_manual/configuration_files/collaborative_documents_configuration.html
https://docs.nextcloud.org/server/9/admin_manual/issues/general_troubleshooting.html (and owncloud.db)
https://docs.nextcloud.org/server/9/developer_manual/general/debugging.html
https://docs.nextcloud.org/server/9/developer_manual/app/index.html
https://docs.nextcloud.org/server/9/developer_manual/app/tutorial.html (also: [owncloud version] tag)
https://docs.nextcloud.org/server/9/developer_manual/core/unit-testing.html
screenshots of owncloud instances (name/logo) used on
https://docs.nextcloud.org/server/9/admin_manual/configuration_server/external_sites.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_files/federated_cloud_sharing_configuration.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_files/default_files_configuration.html
https://docs.nextcloud.org/server/9/admin_manual/configuration_files/external_storage/google.html
https://docs.nextcloud.org/server/9/user_manual/files/gallery_app.html
https://docs.nextcloud.org/server/9/user_manual/files/federated_cloud_sharing.html
https://docs.nextcloud.org/server/9/user_manual/pim/sync_kde.html
https://docs.nextcloud.org/server/9/user_manual/pim/sync_thunderbird.html
https://docs.nextcloud.org/server/9/user_manual/documents.html
other
https://docs.nextcloud.org/server/9/developer_manual/app/changelog.html (“Nextcloud 8.1” OC githubs)
linking to "Owncloud Test pilots in the menu
https://docs.nextcloud.org/server/9/developer_manual/app/middleware.html
https://docs.nextcloud.org/server/9/developer_manual/app/routes.html
https://docs.nextcloud.org/server/9/developer_manual/app/api.html
https://docs.nextcloud.org/server/9/developer_manual/app/configuration.html
https://docs.nextcloud.org/server/9/developer_manual/app/users.html
https://docs.nextcloud.org/server/9/developer_manual/app/logging.html
links to owncloud
https://docs.nextcloud.org/server/9/developer_manual/bugtracker/index.html (solved)
https://docs.nextcloud.org/server/9/developer_manual/bugtracker/codereviews.html
Edit: update obsolete entry
