OpenID offline installation
Hey there,
Trying to offline install “OpenID Connect Login” or “OpenID Connect user backend” or even “Social Login” and I have always the same problem:
“Could not download app X”. The thing is that I have downloaded the .zip from the github official page of the project and I do not understand why Nextcloud tries to download something.
OpenID Connect Login 3.2.0
OpenID Connect user backend 6.3.0dev.0
Social Login 5.9.1
On NExtcloud 28.0.1
Do I miss something?
I have succesfully installed spreed ofline and it works like a charm.
Thank you very much for reading me.
Alejandro
And then what? What did you do after downloading the zip?
On NExtcloud 28.0.1
Not only is v28 end-of-life, but 28.0.1 means you’re are WAY behind on v28 maintenance releases (28.0.14 was the last maintenance release).
