I am trying to install nextcloud 13.0.5-1.0 on 32bit archlinux. When I point my browser to installation wizard,
I get the warning on open_basedir. However, if I comment out the line in /etc/httpd/conf/extras/nextcloud.conf on open_basedir as is suggested by this post, then pointed to installation wizard, my browser shows a blank page. What can I do?
Editted several hours later : it turned out that open_basedir was set in /etc/php/php.ini.
The correct solution is not to delete the open_basedir setting, but to put the correct path in it. This can be done with a php_admin_value in your virtual host, or if you use php_fpm, in the fpm pool.
Just that: put exactly the paths into open_basedir that you need. I would remove /var/www.
“I can comment” does this mean that line in php.ini has a # sign in front? Than it is not actve anyway.
My installation works with php_fpm, and my open_basedir assignments are in
/etc/php/7.4/fpm/pool.d/www-nextcloud.conf. The line looks like this:
