Hi all
I just upgrade my NC server from v17 to v18 Hub using the manual update procedure described in the Admin manual.
It went well and I have now a well functioning 18.0.2 version.
I then installed the 2 apps needed to get OnlyOffice integrated : Community Document Server v0.1.5 and Onlyoffice v4.1.4
I got then an ONLYOFFICE menu in the admin section.
The document server field has been automatically updated with my nextcloud server address (https://mydomaine/nextcloud). It is the address I connect to with my web browser.
I use Letsencrypt for the SSL certificate.
I use NGINX and I have rebooted my server.
Still, when I connect to my nextcloud server using a web browser (admin user or another regular user), I donβt have any entry when I click on the β+β button on the documents page.
What have I missed ?
Thanks for your support!
