I am currently trying to set up a Nextcloud. In doing so, I am encountering the “Bad Siganture” error when it comes to OnlyOffice in conjunction with an external storage that has been encrypted on the server side using Master Key.
The Nextcloud and OnlyOffice Documentserver were created using Docker Compose and are behind a reverse proxy. The external storage was mounted using webDAV.
The environment is currently a pure test environment, so changes like re-setting up the Nextcloud are not a problem.
Here is another post with the same behavior, but nobody answered:
I hope you can help me and thank you in advance.
Error from log:
[webdav] Error: OCP\Encryption\Exceptions\GenericEncryptionException: bad signature on <>.
- /config/www/nextcloud/apps/encryption/lib/Crypto/Crypt.php line 507
OCA\Encryption\Crypto\Crypt->checkSignature(“*** sensitive parameter replaced ***”) - /config/www/nextcloud/apps/encryption/lib/Crypto/Encryption.php line 385
OCA\Encryption\Crypto\Crypt->symmetricDecryptFileContent(“*** sensitive parameter replaces ***”) - /config/www/nextcloud/lib/private/Files/Stream/Encryption.php line 519
OCA\Encryption\Crypto\Encryption->decrypt(“*** sensitive parameter replaces ***”) - /config/www/nextcloud/lib/private/Files/Stream/Encryption.php line 317
OC\Files\Stream\Encryption->readCache() - <>
OC\Files\Stream\Encryption->stream_read() - /config/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php line 55
fread() - /config/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/CallbackWrapper.php line 96
Icewind\Streams\Wrapper->stream_read(). - <>
Icewind\Streams\CallbackWrapper->stream_read() - /config/www/nextcloud/3rdparty/sabre/http/lib/Sapi.php line 110
stream_copy_to_stream() - /config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 490
Sabre\HTTP\Sapi::sendResponse() - /config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod() - /config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start() - /config/www/nextcloud/apps/dav/lib/Server.php line 360
Sabre\DAV\Server->exec() - /config/www/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec() - /config/www/nextcloud/remote.php line 171
require_once(“/config/www/nex … p”)
TL;DR Is there any way to use OnlyOffice in conjunction with encrypted external storage in Nextcloud?
Kind regards
Zobrac
