example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud Hub II (23.0.6)
Operating system and version (eg, Ubuntu 20.04): Linux 5.4.0-113-generic x86_64
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.4): PHP 7.4.3
Is this the first time you’ve seen this error? (Y/N):N
- Open document on moblie which is not work, but it still work on the web portal.
onlyoffice GuzzleHttp\Exception\ServerException: Server error: `POST https://ndocs.netcraft.com.mo/index.php/apps/documentserver_community/ConvertService.ashx` resulted in a `500 Internal Server Error` response: <!DOCTYPE html> <html class="ng-csp" data-placeholder-focus="false" lang="en" data-locale="en" > <head data-requesttok (truncated...)
/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php - line 69:
GuzzleHttp\Exception\RequestException::create()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 204:
GuzzleHttp\Middleware::GuzzleHttp\{closure}("*** sensiti ... *")
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 153:
GuzzleHttp\Promise\Promise::callHandler()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php - line 48:
GuzzleHttp\Promise\Promise::GuzzleHttp\Promise\{closure}("*** sensiti ... *")
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 248:
GuzzleHttp\Promise\TaskQueue->run()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 224:
GuzzleHttp\Promise\Promise->invokeWaitFn()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 269:
GuzzleHttp\Promise\Promise->waitIfPending()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 226:
GuzzleHttp\Promise\Promise->invokeWaitList()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 62:
/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php - line 187:
GuzzleHttp\Promise\Promise->wait()
/var/www/nextcloud/lib/private/Http/Client/Client.php - line 294:
GuzzleHttp\Client->request()
/var/www/nextcloud/apps/onlyoffice/lib/documentservice.php - line 372:
OC\Http\Client\Client->post()
/var/www/nextcloud/apps/onlyoffice/lib/documentservice.php - line 177:
OCA\Onlyoffice\DocumentService->Request()
/var/www/nextcloud/apps/onlyoffice/lib/documentservice.php - line 91:
OCA\Onlyoffice\DocumentService->SendRequestToConvertService()
/var/www/nextcloud/apps/onlyoffice/lib/preview.php - line 269:
OCA\Onlyoffice\DocumentService->GetConvertedUri()
/var/www/nextcloud/lib/private/Preview/ProviderV1Adapter.php - line 53:
OCA\Onlyoffice\Preview->getThumbnail()
/var/www/nextcloud/lib/private/Preview/GeneratorHelper.php - line 62:
OC\Preview\ProviderV1Adapter->getThumbnail()
/var/www/nextcloud/lib/private/Preview/Generator.php - line 246:
OC\Preview\GeneratorHelper->getThumbnail()
/var/www/nextcloud/lib/private/Preview/Generator.php - line 141:
OC\Preview\Generator->getMaxPreview()
/var/www/nextcloud/lib/private/Preview/Generator.php - line 110:
OC\Preview\Generator->generatePreviews()
/var/www/nextcloud/lib/private/PreviewManager.php - line 212:
OC\Preview\Generator->getPreview()
/var/www/nextcloud/core/Controller/PreviewController.php - line 169:
OC\PreviewManager->getPreview()
/var/www/nextcloud/core/Controller/PreviewController.php - line 142:
OC\Core\Controller\PreviewController->fetchPreview()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 217:
OC\Core\Controller\PreviewController->getPreviewByFileId()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 126:
/var/www/nextcloud/lib/private/AppFramework/App.php - line 157:
/var/www/nextcloud/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main()
/var/www/nextcloud/lib/base.php - line 1008:
OC\Route\Router->match()
/var/www/nextcloud/index.php - line 36:
OC::handleRequest()
OCP\Files\NotFoundException: /appdata_ocru8ytkzh2p/documentserver_community/doc_1769759011/Editor.bin
/var/www/nextcloud/lib/private/Files/Node/Folder.php - line 146:
OC\Files\Node\Root->get()
/var/www/nextcloud/lib/private/Files/SimpleFS/SimpleFolder.php - line 75:
OC\Files\Node\Folder->get()
/var/www/nextcloud/apps/documentserver_community/lib/Document/DocumentStore.php - line 105:
OC\Files\SimpleFS\SimpleFolder->getFile()
/var/www/nextcloud/apps/documentserver_community/lib/Controller/ConvertController.php - line 59:
OCA\DocumentServer\Document\DocumentStore->getDocumentForEditor()
OCA\DocumentServer\Controller\ConvertController->convert()
OC::handleRequest()
'passwordsalt' => '123456789',
'secret' => '123456789',
0 => 'localhost',
1 => 'X.X.X.X',
2 => 'test.com',
'datadirectory' => '/ndata/ncdata',
'dbtype' => 'pgsql',
'version' => '23.0.6.1',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'cccccccc',
'dbpassword' => 'ccccccccc',
'instanceid' => 'ccccccccc',
'log_type' => 'file',
'loglevel' => '2',
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'mail_smtpmode' => 'smtp',
'logtimezone' => 'Etc/UTC',
'theme' => '',
'mail_from_address' => 'test',
'mail_domain' => 'testing.com',
'mail_smtphost' => 'X.X.X.X',
'mail_smtpport' => '25',
'allow_local_remote_servers' => true,
'updater.secret' => '123456789',
