Originally published at: October maintenance updates for Nextcloud Hub 26 Winter, Spring and Summer - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 26 Winter, Spring or Summer, we strongly recommend you to update to version 33.0.10, 34.0.5 or 35.0.2 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
Maintenance updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
- Nextcloud Hub 26 Winter (version 33.0.10)
- Nextcloud Hub 26 Spring (version 34.0.5)
- Nextcloud Hub 26 Summer (version 35.0.2)
Nextcloud Hub 26 Summer for enterprises
With version 35.0.2, Nextcloud Hub 26 Sunner is available to the Nextcloud Enterprise customers. This means that enterprise users now have access to the latest features introduced in Nextcloud Hub 26 Summer.
As always, we begin with a staged rollout, starting at 30% of the instances.
Nextcloud Hub 26 Summer: Autonomy for Teams, Office on desktop, a fresh take on Photos
Created in a joint effort of our team, community, and partners, Nextcloud Hub 26 Summer learns from real people using our tools every day. Discover our latest release and take it for a test drive.
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
