NC version: 24.0.3
Hosted on a BlueHost instance, PHP version 7.4
Hi, I’m trying to execute a get request for a list of all users in the NC instance.
The cURL command is executing 100%, but doing it in Excel VBA is simply not succeeding.
My code in VBA:
Sub VBA_XML_API()
'declare the xml object
Dim xml_obj As New MSXML2.XMLHTTP60
base_url = “https://nextcloud.mydomain.com”
Endpoint = “/ocs/v1.php/cloud/users”
API_URL = base_url + Endpoint
’ Open the request
xml_obj.Open “GET”, API_URL, False ’ did try with bstrUser and bstrPassword without Auth header, but no success
’ set the header value
xml_obj.setRequestHeader “Authorisation”, “Basic stringCopiedFromPostmanTestHeader”
xml_obj.setRequestHeader “OCS-APIRequest”, “true”
’ send request to NextCloud API
xml_obj.send
'Check response
If xml_obj.Status <> 200 Then
Debug.Print xml_obj.Status & " - " & xml_obj.statusText
’ constantly getting "https://nextcloud.mydomain.com/ocs/v1.php/cloud/users
’ 401 - "
Exit Sub
Else
Debug.Print xml_obj.responseText
End If
End Sub
Is there anybody that can help me on this?
Assistance will really be appreciated.
[/details]
Nextcloud version (eg, 20.0.5): 24.0.3
PHP version (eg, 7.4): replace me
Microsoft Excel 365 on Windows 11
Can’t get the VBA call to work
(no logging happens although all levels are selected)
application/x-httpd-php config.php ( PHP script text )
'instanceid' => 'wefwefwe',
'passwordsalt' => 'wefwefwef',
'secret' => 'wfwefwefwe',
0 => 'nextcloud.mydomain.com',
'datadirectory' => '/home1/dsthyshsfh/data',
'version' => '24.0.3.2',
'overwrite.cli.url' => 'https://nextcloud.mydomain.com',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'bmhnj',
'dbpassword' => 'dfghj',
'default_language' => 'en',
'default_locale' => 'en_US',
'force_language' => false,
'default_phone_region' => 'ZA',
'knowledgebaseenabled' => true,
'remember_login_cookie_lifetime' => 1296000,
'session_lifetime' => 86400,
'session_keepalive' => true,
'auto_logout' => false,
'auth.bruteforce.protection.enabled' => true,
'mail_from_address' => 'xxxx',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'gmail.com',
'mail_smtphost' => 'smtp.gmail.com',
'mail_smtpport' => '587',
'mail_smtpsecure' => 'tls',
'app_install_overwrite' =>
0 => 'nextant',
1 => 'printer',
2 => 'files_lock',
3 => 'cpanelmailsync',
4 => 'nextbackup',
5 => 'ownbackup',
6 => 'loganalyzer',
7 => 'workin2gether',
8 => 'spreedme',
9 => 'occweb',
'mail_smtpauth' => 1,
'mail_smtpname' => 'xxxx@gmail.com',
'mail_smtppassword' => 'dfshgrth',
'theme' => '',
'loglevel' => 2,
'auth.webauthn.enabled' => false,
'updater.secret' => 'xxxxx',
