after upgrading from v12 to v13, I encounter a NotPermittedException when specific users log into their accounts. What can I do to solve this issue?
Nextcloud version: 13.0.2
Operating system and version: 4.15.15-1-ARCH
Apache or nginx version: Apache/2.4.33
PHP version: 7.2.4
Long login times w/ LDAP user accounts
OCP\Files\NotPermittedException: No delete permission for path
/srv/http/nextcloud/lib/private/Files/SimpleFS/SimpleFolder.php - line 65: OC\Files\Node\Folder->delete()
/srv/http/nextcloud/apps/dav/lib/CardDAV/PhotoCache.php - line 265: OC\Files\SimpleFS\SimpleFolder->delete()
/srv/http/nextcloud/apps/dav/lib/AppInfo/Application.php - line 143: OCA\DAV\CardDAV\PhotoCache->delete('1', 'LDAP user.vcf')
[internal function] OCA\DAV\AppInfo\Application->OCA\DAV\AppInfo\{closure}(*** sensitive parameters replaced ***)
/srv/http/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php - line 212: call_user_func(Object(Closure), Object(Symfony\Component\EventDispatcher\GenericEvent), '\\OCA\\DAV\\CardDA...', Object(Symfony\Component\EventDispatcher\EventDispatcher))
/srv/http/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php - line 44: Symfony\Component\EventDispatcher\EventDispatcher->doDispatch(Array, '\\OCA\\DAV\\CardDA...', Object(Symfony\Component\EventDispatcher\GenericEvent))
/srv/http/nextcloud/apps/dav/lib/CardDAV/CardDavBackend.php - line 683: Symfony\Component\EventDispatcher\EventDispatcher->dispatch('\\OCA\\DAV\\CardDA...', Object(Symfony\Component\EventDispatcher\GenericEvent))
/srv/http/nextcloud/apps/dav/lib/CardDAV/SyncService.php - line 285: OCA\DAV\CardDAV\CardDavBackend->updateCard('1', 'LDAP user.vcf', 'BEGIN VCARD\r\nVE...')
/srv/http/nextcloud/apps/dav/lib/HookManager.php - line 124: OCA\DAV\CardDAV\SyncService->updateUser(Object(OC\User\User))
/srv/http/nextcloud/lib/private/legacy/hook.php - line 106: OCA\DAV\HookManager->changeUser(Array)
/srv/http/nextcloud/lib/private/Server.php - line 409: OC_Hook emit('OC_User', 'changeUser', Array)
[internal function] OC\Server->OC\{closure}(*** sensitive parameters replaced ***)
/srv/http/nextcloud/lib/private/Hooks/EmitterTrait.php - line 99: call_user_func_array(Object(Closure), Array)
/srv/http/nextcloud/lib/private/Hooks/PublicEmitter.php - line 36: OC\Hooks\BasicEmitter->emit('\\OC\\User', 'changeUser', Array)
/srv/http/nextcloud/lib/private/User/User.php - line 456: OC\Hooks\PublicEmitter->emit('\\OC\\User', 'changeUser', Array)
/srv/http/nextcloud/lib/private/Avatar.php - line 149: OC\User\User->triggerChange('avatar', Object(OC\Files\SimpleFS\SimpleFile))
/srv/http/nextcloud/apps/user_ldap/lib/User/User.php - line 596: OC\Avatar->set('\xFF\xD8\xFF\xE0\x00\x10JFIF\x00\x01\x01\x01\x00...')
/srv/http/nextcloud/apps/user_ldap/lib/User/User.php - line 571: OCA\User_LDAP\User\User->setOwnCloudAvatar()
/srv/http/nextcloud/apps/user_ldap/lib/User/User.php - line 553: OCA\User_LDAP\User\User->updateAvatar()
/srv/http/nextcloud/lib/private/legacy/hook.php - line 106: OCA\User_LDAP\User\User->updateAvatarPostLogin(Array)
/srv/http/nextcloud/lib/private/Server.php - line 398: OC_Hook emit('OC_User', 'post_login', Array)
/srv/http/nextcloud/lib/private/Hooks/PublicEmitter.php - line 36: OC\Hooks\BasicEmitter->emit('\\OC\\User', 'postLogin', Array)
/srv/http/nextcloud/lib/private/User/Session.php - line 368: OC\Hooks\PublicEmitter->emit('\\OC\\User', 'postLogin', Array)
/srv/http/nextcloud/core/Controller/LoginController.php - line 282: OC\User\Session->completeLogin(*** sensitive parameters replaced ***)
[internal function] OC\Core\Controller\LoginController->tryLogin(*** sensitive parameters replaced ***)
/srv/http/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 161: call_user_func_array(Array, Array)
/srv/http/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 91: OC\AppFramework\Http\Dispatcher->executeController(Object(OC\Core\Controller\LoginController), 'tryLogin')
/srv/http/nextcloud/lib/private/AppFramework/App.php - line 115: OC\AppFramework\Http\Dispatcher->dispatch(Object(OC\Core\Controller\LoginController), 'tryLogin')
/srv/http/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47: OC\AppFramework\App main('OC\\Core\\Control...', 'tryLogin', Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
[internal function] OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
/srv/http/nextcloud/lib/private/Route/Router.php - line 297: call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
/srv/http/nextcloud/lib/base.php - line 999: OC\Route\Router->match('/login')
/srv/http/nextcloud/index.php - line 37: OC handleRequest()
{main}
2018-05-09T20:43:44+0200
