Nextcloud version: 20.0.0
Operating system and version: nextcloud:fpm-alpine
Apache or nginx version: nginx:latest
PHP version: 7.3
Issue
After upgrading to Nextcloud 20, when running occ
, the application will start but neither log anything nor return, being stuck at 100% CPU usage. Even a plain ./occ
will not return. It does not matter whether occ
is called from outside or from inside the container:
sudo docker exec -u 1000 nextcloud php occ
Note, that calling occ
from OCCWeb
works.
Is this the first time you’ve seen this error?: Y
- Upgrade from Nextcloud 19.0.0.3 to 20
- Try to run
occ
No log output generated by occ
, nor any other error or informational message.
No log output generated when callingocc
Not relevant, because no HTTP request is issued.
