Hello all,
example
longer
example
here
Nextcloud version: 18.0.3 for Server
Operating system and version: Ubuntu 18.04.4 LTS (Bionic Beaver)
Apache or nginx version: Apache/2.4.29
PHP version: PHP 7.2.24
unfortunately I can not get any further myself and find nothing in the forum.
I added the “Preview Generator” app and then ran the following command via occ “/ occ preview: generate-all -vvv”
meanwhile we had a power outage now comes the following message.
What can I do?
ghost@homeserver:/mnt/2TB/shares$ sudo -u www-data php /var/www/html/nextcloud/occ
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: could not find driver in /var/www/html/nextcloud/lib/private/DB/Connection.php:68
Stack trace:
#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(420): OC\DB\Connection->connect()
#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(380): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(324): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(683): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/html/nextcloud/lib/private/DB/Connection.php(155): Doctrine\DBAL\Connection->setTransactionIsolation()
#5 /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(195): OC\DB\Connection->__construct()
#6 /var/www/html/nextcloud/lib/private/DB/ConnectionFactory.php(157): Doctrine\DBAL\DriverManager::getConnection()
#7 /var/www/html/nextcloud/lib/private/Server.php(748): OC\DB\ConnectionFactory->getConnection()
#8 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#9 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#10 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\ServerContainer->query()
#11 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#12 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#13 /var/www/html/nextcloud/lib/private/Server.php(1664): OC\ServerContainer->query()
#14 /var/www/html/nextcloud/lib/private/Server.php(421): OC\Server->getDatabaseConnection()
#15 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#16 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#17 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(70): OC\ServerContainer->query()
#18 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(100): OC\AppFramework\Utility\SimpleContainer->buildClass()
#19 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(115): OC\AppFramework\Utility\SimpleContainer->resolve()
#20 /var/www/html/nextcloud/lib/private/ServerContainer.php(150): OC\AppFramework\Utility\SimpleContainer->query()
#21 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(70): OC\ServerContainer->query()
#22 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(100): OC\AppFramework\Utility\SimpleContainer->buildClass()
#23 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(115): OC\AppFramework\Utility\SimpleContainer->resolve()
#24 /var/www/html/nextcloud/lib/private/ServerContainer.php(150): OC\AppFramework\Utility\SimpleContainer->query()
#25 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\ServerContainer->query()
#26 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#27 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#28 /var/www/html/nextcloud/lib/private/Server.php(433): OC\ServerContainer->query()
#29 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#30 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#31 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\ServerContainer->query()
#32 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#33 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#34 /var/www/html/nextcloud/lib/private/Server.php(1540): OC\ServerContainer->query()
#35 /var/www/html/nextcloud/lib/private/Server.php(801): OC\Server->getUserSession()
#36 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#37 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#38 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(162): OC\ServerContainer->query()
#39 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#40 /var/www/html/nextcloud/lib/private/ServerContainer.php(125): Pimple\Container->offsetGet()
#41 /var/www/html/nextcloud/lib/private/Server.php(1835): OC\ServerContainer->query()
#42 /var/www/html/nextcloud/lib/private/legacy/app.php(347): OC\Server->getAppManager()
#43 /var/www/html/nextcloud/lib/private/legacy/app.php(114): OC_App::getEnabledApps()
#44 /var/www/html/nextcloud/lib/base.php(645): OC_App::loadApps()
#45 /var/www/html/nextcloud/lib/base.php(1089): OC::init()
#46 /var/www/html/nextcloud/console.php(48): require_once('/var/www/html/n...')
#47 /var/www/html/nextcloud/occ(11): require_once('/var/www/html/n...')
#48 {main}ghost@homeserver:/mnt/2TB/shares$
{"reqId":"vhJzXD3Z93TBu0U7aAIv","level":3,"time":"2020-04-08T12:50:04+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Error while sending QUERY packet. PID=18779 at /var/www/html/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#117","userAgent":"--","version":"18.0.3.0"}
{"reqId":"JvyzzobOFZRHMkz4cikR","level":3,"time":"2020-04-08T13:02:53+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"ovrzY7x3ytfOsVom4psv","level":3,"time":"2020-04-08T13:03:43+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"4xuFHCkJQrqYF5DaMUWw","level":3,"time":"2020-04-08T13:04:41+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"rrgjMsQvBeXwD9TbVfWC","level":3,"time":"2020-04-08T13:05:30+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"2vRzlvKHrYRpIeXhgjyQ","level":3,"time":"2020-04-08T13:06:29+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"1OoPEYdnadh9dU3iu267","level":3,"time":"2020-04-08T13:08:37+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"z21TMYACiuEyUEhV6O92","level":3,"time":"2020-04-08T13:09:10+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"2NfZ8VkiQNHfCLOqWfQC","level":3,"time":"2020-04-08T13:16:27+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"vZE4xj67WThJvdKrjTd5","level":3,"time":"2020-04-08T13:17:18+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"eXfSHMwqKpl7881Ya5ds","level":3,"time":"2020-04-08T13:19:02+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"VHiPrtYepxjw4Ni9UMxC","level":3,"time":"2020-04-08T13:20:08+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"Cn6X2JCnOIqwCLOQGhZJ","level":3,"time":"2020-04-08T13:25:30+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"A6LvVzYByJwPgnGerjwF","level":3,"time":"2020-04-08T13:26:31+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"QAcYZAvvyq7rrE0hBF9Z","level":3,"time":"2020-04-08T13:29:32+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"zDNT77YS7lc7plzQdat8","level":3,"time":"2020-04-08T13:29:37+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"tOXuprSWsK7ZvJ0IYBzZ","level":3,"time":"2020-04-08T13:41:03+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"LjrOO2LFq2Rtosylmy1O","level":3,"time":"2020-04-08T13:43:37+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
{"reqId":"x9J95HLcf69tddR9D4la","level":3,"time":"2020-04-08T14:05:22+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/html/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18","userAgent":"--","version":"18.0.3.0"}
'instanceid' => 'oczdhaad85rl',
'passwordsalt' => 'XXXXXXXXXXXXXXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXXXXXXXXXXXX',
0 => 'XXXXXXXXXXXXXXXXX.ddns.net',
'datadirectory' => '/mnt/2TB/nextcloud',
'version' => '18.0.3.0',
'overwrite.cli.url' => 'https://XXXXXXXXXXXXXX.ddns.net',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXXXXXXXXXXXXX',
The output of your Apache/nginx/system log in /var/log/error.log
[Wed Apr 08 15:00:16.981488 2020] [mpm_prefork:notice] [pid 6047] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1d con$
[Wed Apr 08 15:00:16.981549 2020] [core:notice] [pid 6047] AH00094: Command line: '/usr/sbin/apache2'
