Nextcloud version: 20.0.1
Operating system and version: Ubuntu 20.04
Apache 2.4
PHP version 7.4
when trying to do an update to 20.0.2 I crashed everything yesterday, on restoring the backup file with
mysql -h [server] -u [username] -p[password] [db_name] < nextcloud-sqlbkp.bak
I now end up with an error:
Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing ‘SELECT
id
,numeric_id
,available
,last_checked
FROMoc_storages
WHEREid
= ?’ with params [“local::/media/owncloud-data/”]:SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘nextcloud.oc_storages’ doesn’t exist
Update failed
Is there a way to regenerate this table ? I do not have a lot of “storages” , actually only exactly 1 , so even if I could just get the table structure it might help me
thank you
