OC\ServerNotAvailableException: Could not decrypt key
example
longer
example
here
Nextcloud version (eg, 20.0.5): 22.2.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 7.4
  1. Upload the new update
  2. Ran updter got an error
  3. Updater failed
Preparing update
Set log level to debug
Turned on maintenance mode
Repair step: Repair MySQL collation
Repair info: All tables already have the correct collation -> nothing to do
Repair step: Repair SQLite autoincrement
Repair step: Copy data from accounts table when migrating from ownCloud
Repair step: Drop account terms table when migrating from ownCloud
Updating database schema
Updated database
Updated "federation" to 1.13.0
Updated "lookup_server_connector" to 1.11.0
Repair step: Update OAuth token expiration times
Updated "oauth2" to 1.11.0
Updated "password_policy" to 1.13.0
Updated "files" to 1.18.0
Repair step: Upgrading Circles App
Updated "circles" to 23.1.2
Updated "cloud_federation_api" to 1.6.0
Repair step: Fix component of birthday calendars
Repair info: 1 birthday calendars updated.
Repair step: Regenerating birthday calendars to use new icons and fix old birthday events without year
Repair info: Repair step already executed
Repair step: Fix broken values of calendar objects
[0 / 0]: Fix broken values of calendar objects
Repair step: Registering building of calendar search index as background job
Repair step: Register building of social profile search index as background job
Repair step: Registering background jobs to update cache for webcal calendars
Repair info: Added 0 background jobs to update webcal calendars
Repair step: Registering building of calendar reminder index as background job
Repair step: Clean up orphan event and contact data
Repair info: 0 events without a calendar have been cleaned up
Repair info: 0 properties without an events have been cleaned up
Repair info: 0 changes without a calendar have been cleaned up
Repair info: 0 cached events without a calendar subscription have been cleaned up
Repair info: 0 changes without a calendar subscription have been cleaned up
Repair info: 0 contacts without an addressbook have been cleaned up
Repair info: 0 properties without a contact have been cleaned up
Repair info: 0 changes without an addressbook have been cleaned up
Repair step: Remove activity entries of private events
Repair info: Removed 0 activity entries
Repair step: Clean up old calendar subscriptions from deleted users that were not cleaned-up
[0 / 0]: Clean up old calendar subscriptions from deleted users that were not cleaned-up
Repair info: 0 calendar subscriptions without an user have been cleaned up
Updated "dav" to 1.21.0
The update was unsuccessful. Please report this issue to the Nextcloud community.
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
Now i get this error:
Update to 23.0.12
Detailed logs
Preparing update
Repair info: All tables already have the correct collation → nothing to do
Updated database
