Good Morning guys
Just did the migration from OwnCloud 9.0.2. to NextCloud 9.0.5
I’m using OC/NC on Hosted Server from ALL-INKL on PHP 7.0 (CGI)
–> upgrade process went fine but now I’m seeing the followin (probably minor) issues on NextCloud when I login as ADmin:
1.) some Apps can not be activated…
- in this case e.g. App: Registration 0.1.3
ErrorMessage: " Die App kann nicht installiert werden, weil sie unerlaubten code enthält"
2.) and more important some failed Integrity Checks
Fehler/Meldung: “Es gab Probleme mit dem Code - Integritätsprüfung. Mehr Informationen…”
…and further if I follow the link to https:// “MEINECLOUD”…/index.php/settings/integrity/failed:
SHOULD I BE CONCEARNED about these (maybe outdated) files ??
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- core
- INVALID_HASH
- core/doc/admin/_sources/configuration_files/collaborative_documents_configuration.txt
- core/doc/admin/_static/img/note_pencil.svg
- core/doc/admin/_static/img/warning.svg
- core/doc/admin/_static/style.css
- core/fonts/LICENSE.txt
- core/vendor/jquery-migrate/jquery-migrate.js
- core/vendor/jquery-migrate/jquery-migrate.min.js
- core/vendor/jsTimezoneDetect/jstz.js
- EXTRA_FILE
- usage/.htaccess
- usage/.htpasswd
- INVALID_HASH
- files_texteditor
- INVALID_HASH
- js/vendor/ace/src-noconflict/mode-diff.js
- INVALID_HASH
- files_external
- INVALID_HASH
- 3rdparty/Dropbox/API.php
- INVALID_HASH
etc…
ANY Comments on this ??
Thank’s
Oliver
